It is currently Thu Sep 18, 2025 8:08 am
PostPosted: Tue Oct 12, 2010 2:50 pm
All the diagrams I've seen show grounding to the bridge. What do you do in the case of an archtop with floating bridge? I have 2 humbuckers, 2 vol, 2 tone and a 3-way switch.
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Tue Oct 12, 2010 6:33 pm
Most people, if inclined to ground the strings, ground the tailpiece if metal, or add a strip of brass to the underside of a wooden tailpiece and ground to that.
PostPosted: Tue Oct 12, 2010 6:34 pm
First name: shad
Last Name: peters
you should still be able to ground to the bridge, just run a wire from your electronics to one of the bridge posts, should be the same as any other tune-o-matic.
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Tue Oct 12, 2010 7:15 pm
There has to be a more elegant solution. I have a wood base to the bridge and a Benedetto type tailpiece. Can't imagine a wire running to either one.
Rich Smith
Issaquah, WA
PostPosted: Tue Oct 12, 2010 8:05 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
If it makes noise, and it bothers you, you could try a wrist ground.
A bracelet that ties into the ground somewhere.
My advise to somebody that doesn't like a noisy guitar or amp is,
play it, then you won't hear the noise.
PostPosted: Fri Oct 15, 2010 8:55 pm
First name: Brett
Last Name: Faust
City: Puyallup
Zip/Postal Code: 98373
See a Norlin era Les Paul wiring harness. Notice no ground connection to strings but very thorough shielding even a jack "can".
How long is that in luthyears?
PostPosted: Sat Oct 16, 2010 11:12 am
I ended up attaching a wire to the low E string ball end and running it to the output jack. The bridge is a tune-o-matic so should ground the other strings.
Rich Smith
Issaquah, WA
