Wiring http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10123&t=28682 |
Author: | skankstro [ Thu Aug 19, 2010 8:35 pm ] |
Post subject: | Wiring |
Could there be someone willing to help me? im bulding my first guitar and need help wiring if so please tell me! ![]() neck pickup= humbucker (gibson 57 classic) middle pickup= single coil (P-94R - Humbucker-Sized P-90 - Single Coil) bridge pickup= humbucker (gibson 57 classic) 1 tone and volume to each pickup (500k pots, .22uf caps for tones) (no caps for the volume) 1 rotary switch if anything is missing or need anything else please let me know, and no im not using a push-pull nob. |
Author: | JohnAbercrombie [ Thu Aug 19, 2010 11:08 pm ] |
Post subject: | Re: Wiring |
Matthew- What do you want to do with the rotary switch? And what kind of rotary switch do you have? John |
Author: | Ricardo [ Fri Aug 20, 2010 12:14 am ] |
Matthew, the Seymour Duncan site: http://www.seymourduncan.com/support/wiring-diagrams/ has a lot of wiring diagrams. Maybe it will help you. |
Author: | JohnAbercrombie [ Fri Aug 20, 2010 12:26 am ] |
Rich- Thanks for that link - now bookmarked here. John |
Author: | skankstro [ Fri Aug 20, 2010 8:16 pm ] |
john i want the rotary switch to be a pickup selector and i dont know what kind |
Author: | JohnAbercrombie [ Fri Aug 20, 2010 8:49 pm ] |
skankstro wrote: john i want the rotary switch to be a pickup selector and i dont know what kind Things can get complicated in a hurry if you start trying to get a lot of different 'combinations' - and some of them may not be that 'interesting'-sounding.... or what you had in mind. Using one of the 'standard' setups from the Duncan site, or trying out some combos with the pickups in a cheap 'test guitar' might give you some ideas. Cheers John |
Author: | Mustang_jt [ Sat Aug 21, 2010 7:17 am ] |
Lots of wiring diagrams here http://www.guitarelectronics.com/category/wiring_resources_guitar_wiring_diagrams.3_pickup_guitar_wiring_diagrams/ cheers John |
Author: | skankstro [ Sat Aug 21, 2010 12:54 pm ] |
JohnAbercrombie wrote: skankstro wrote: john i want the rotary switch to be a pickup selector and i dont know what kind Things can get complicated in a hurry if you start trying to get a lot of different 'combinations' - and some of them may not be that 'interesting'-sounding.... or what you had in mind. Using one of the 'standard' setups from the Duncan site, or trying out some combos with the pickups in a cheap 'test guitar' might give you some ideas. Cheers John your right maybe i should just use a 5-way |
Author: | skankstro [ Sat Aug 21, 2010 11:45 pm ] |
the links dont quite have what i want, im talking 5-way switch, humbuckers for the bridge and neck (specifically Gibson 57 classic) and a single-coil for the middle (specifically Gibson P-94R - Humbucker-Sized P-90 - Single Coil) wired to 500k pots with .20 capacitors for the tone. and obviously a jack. |
Author: | JohnAbercrombie [ Sun Aug 22, 2010 1:25 am ] |
If you're not interested in running the humbuckers in single-coil/'split' mode, then you can just treat them like any single coil pickup - you'll have three pickups with two leads each- and one of the leads from each pickup will be connected to ground. So the wiring becomes fairly simple. I'm not sure about the output levels of your humbuckers and P-90 and how they will work when played together, but you will have a volume control on each pickup to help with that issue. Cheers John |
Author: | skankstro [ Mon Aug 23, 2010 12:40 pm ] |
JohnAbercrombie wrote: If you're not interested in running the humbuckers in single-coil/'split' mode, then you can just treat them like any single coil pickup - you'll have three pickups with two leads each- and one of the leads from each pickup will be connected to ground. So the wiring becomes fairly simple. I'm not sure about the output levels of your humbuckers and P-90 and how they will work when played together, but you will have a volume control on each pickup to help with that issue. Cheers John could you please give me a diagram? im not very good at wiring lol |
Author: | JohnAbercrombie [ Mon Aug 23, 2010 2:34 pm ] |
skankstro wrote: could you please give me a diagram? im not very good at wiring lol Time to 'hit the books'..... http://www.1728.com/guitar.htm |
Author: | skankstro [ Mon Aug 23, 2010 9:07 pm ] |
thanks |
Author: | JohnAbercrombie [ Mon Aug 23, 2010 9:16 pm ] |
Matthew- If you don't already own one, keep your eyes open for a cheap multimeter (needle-type- not digital). It's a big help in figuring out how switches work, and other 'troubleshooting' stuff. It's not that complicated, really- you'll see! Cheers John |
Author: | alan stassforth [ Tue Aug 24, 2010 9:57 am ] |
thanks, john. pretty much sums it all up, all on one page. |
Author: | Mike Baker [ Tue Aug 24, 2010 1:34 pm ] |
alan stassforth wrote: thanks, john. pretty much sums it all up, all on one page. +1! Great resource! Thank you! |
Author: | JohnAbercrombie [ Tue Aug 24, 2010 2:10 pm ] |
Glad to help- I found that 'by accident' pretty quickly when I did a search. Cheers John |
