It is currently Thu Sep 18, 2025 10:19 pm
PostPosted: Wed Jul 29, 2009 12:49 pm
I orderred a fender strat neck off the internet and compared it to the original and the heel of the neck is a good 2mm too thick.
What would be the best tool to use?
I thought of going slow with a block sander but that would take a long time to shave off 2mm, and I'm apprehensive about the sanding getting crooked.
So I'm wondering what would be the ideal tool to buy?
Thanks.
PostPosted: Wed Jul 29, 2009 7:03 pm
Last Name: Shaw
City: Philadelphia
Hand plane. Clamp the neck to a bench and plane away. A block plane would work ok. Finish up with a sanding block. Take a few swipes and measure. You be suprised how fast 2mm can disapear.
PostPosted: Thu Jul 30, 2009 1:10 am
I would be inclined to consider taking material from the body pocket with a router where you have a flat top and back to index for an accurate level cut ... if that makes sense for your project?
Tom Krebs
PostPosted: Thu Jul 30, 2009 8:05 am
I could try taking from the pocket, never thought of that.
PostPosted: Fri Jul 31, 2009 5:01 pm
+1. I've done it both ways, and I'd much prefer to take material from the neck pocket. With a good template and/or the proper bits, it's much easier to keep the bottom of the neck pocket level than the heel itself, but both can work just fine if you're careful.
