It is currently Fri Aug 22, 2025 8:56 am
 Post subject: Floyd Rose Installation
PostPosted: Sun Aug 07, 2016 3:40 pm
I am trying to install a Floyd Rose on my project guitar. How do I determine the right spots to drill for the bridge posts? The scale length of the guitar is 24.75".
PostPosted: Sun Aug 07, 2016 8:48 pm
Follow this link. http://www.stewmac.com/FretCalculator.html
PostPosted: Wed Aug 10, 2016 8:35 pm
Search online. Is it a Floyd, or a copy? You should be able to find instructions online. Scale length is relevant, but there's more too it than that.
PostPosted: Wed Aug 10, 2016 9:10 pm
Hey guys,
StevenWheeler: that's what I used to find the scale length!
dberkowitz: it is a copy
My main issue is how to I find the right spots to drill vertically. Aside from measuring the bridge slots on the bridge itself, what else can be done to ensure that where I am drilling are the correct spots for the bridge to sit parallel to the end of the fingerboard with the right string spacing so that neither of my e strings are hanging over the edge of the neck?
PostPosted: Sun Aug 14, 2016 8:14 am
State: Tennessee
This should help
These users thanked the author Clinchriver for the post (total 2): rawlings (Thu Aug 18, 2016 10:26 am) • Hesh (Sun Aug 14, 2016 8:44 am)
PostPosted: Thu Aug 18, 2016 10:26 am
Clinchriver wrote:
This should help
Wow thank you!!
PostPosted: Tue Apr 25, 2017 9:34 am
First name: William
Last Name: Bustard
Country: CANADA
BE very careful, there are at least 3 versions which are all different,
by a 1/4 inch, not using the correct one will make it wrong and you will not have
the adjustable room to intonate sufficiently.
Its worth it to do a complete mock up if your unsure and it is difficult to know as the tolerances are so close.
You just pick up a chord, go twang, and you're got music. -Sid Vicious
