It is currently Fri Aug 22, 2025 5:33 pm
 Post subject: F Hole binding
PostPosted: Fri Mar 03, 2017 12:55 am
First name: James
State: Maine
I've built quite a few guitars and bound the bodies of quite a few. But I've never done F hole binding until now. I'm a bit hesitant because I'm having a hard time imagining how I'm going to scrape the color off of the binding surface. I can tape the inner edges of the binding of course but how do you go about scraping the front surface of the binding?
 Post subject: Re: F Hole binding
PostPosted: Fri Mar 03, 2017 1:24 am
I use a razor blade, and a lot of care.
PostPosted: Fri Mar 03, 2017 2:28 am
First name: James
State: Maine
Yeah I use a razor blade for the outer binding and it's a piece of cake. I put a thick wrap of masking tape around the razor blade to create a stop and zip around the guitar. Works great. I'm just having a hard time visualizing how I'm going to use the same method for the f hole. The f hole is small with tight corners. I was considering cutting a razor blade to about 1/4 size so I can get in there.
PostPosted: Fri Mar 03, 2017 8:10 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I use an exato blade on F holes cause it is smaller. Like everything it takes skill, poise and confidence.
Brian
PostPosted: Fri Mar 03, 2017 8:40 am
A narrow chisel works for scraping the top of f-hole bindings. I use a variety of plane blade offcuts of for stuff like this, I like the extra rigidity and the fact that they can be sharpened. A few wraps of masking tap makes a nice "handle".
PostPosted: Fri Mar 03, 2017 12:08 pm
First name: Freeman
Last Name: Keller
Ditto on the razor blade. Before I put the back on I mask the insides of the f-holes as well as pickup cavities and holes for any electronics. If its plastic binding I shoot color coats over it and scrape back, I have tried to mask f-holes with the 1/4 inch pin strip masking tape with mixed results (auto finishing supply). When the finish is done I use a little hooked end tool (its whats called a "dental explorer") to break the masking tape loose from the inside of the guitar and fish it back out thru the f-hole.
I just finished an archtop with maple binding and I did bind the f-holes in wood. This isn't a very good picture but I'm pretty happy with it
