It is currently Fri Nov 22, 2024 7:29 pm
 Post subject: Fender TBX tone control
PostPosted: Sun Aug 10, 2014 10:29 pm
First name: Van
Last Name: Savage
City: Marion
State: AR
Zip/Postal Code: 72364
I built a guitar with Lace Sensor Duallys, splitted them with miniswitches and used a TBX tone control. Everything works according to plan except the TBX. When I turn it up past the detent into treble it makes a pretty wicked hum. Any help or tips will be much appreciated.
Cheers, Van
PostPosted: Sun Aug 10, 2014 11:37 pm
When they are split, they are single coils. And single coils hum.
These users thanked the author Chris Pile for the post: Van Savage (Wed Aug 27, 2014 9:20 pm)
PostPosted: Wed Aug 13, 2014 10:01 pm
First name: Van
Last Name: Savage
City: Marion
State: AR
It makes a high pitched hum regardless of whether they're split or in dual mode.
PostPosted: Wed Aug 13, 2014 11:22 pm
Then you have other problems.
Is it grounded?
PostPosted: Thu Aug 14, 2014 7:43 am
Last Name: Wilson
Country: Scotland
Sounds like an earth problem. I fitted one to a 90s strat years ago and had a similar problem. That turned out to be a broken wire. Using a multimeter check for continuity between all your grounds and bridge ect. I'll bet one is of high resistance or broken/missing, the tbx pot shouldnt cause a problem itself, its just two pots in one that switch over at pos5. Double check your wiring against the diagram too.
Is it a fender made tbx?
These users thanked the author mechanix for the post: Van Savage (Wed Aug 27, 2014 9:20 pm)
PostPosted: Thu Aug 14, 2014 12:39 pm
Last Name: Wilson
Country: Scotland
Thinking about this earlier and if it only does it on one pot then it's probably wiring or a faulty pot or cap. The only thing i have with tbx is a '97 USA std strat which i fitted a couple of years back.
so i took the plate off and took a pic for you.
The cap is only connected from the bottom pot of the tbx to the body, so that would probably be my first check van.
PostPosted: Thu Aug 14, 2014 9:29 pm
First name: Van
Last Name: Savage
City: Marion
State: AR
Thanks for the photo and all the suggestions. Yes, it is a Fender TBX and yes, I will get busy with it this weekend. My soldering leaves much to be desired and my glob of ground wires soldered to the vol. pot are a mess. Maybe I'll pull them loose and do it again for the third time.
Thanks again.
Users browsing this forum: No registered users and 47 guests
