It is currently Sat Aug 23, 2025 1:59 am
 Post subject: neck holes
PostPosted: Thu Mar 27, 2014 5:54 pm
First name: Matthew
Last Name: Lucas
City: Saugerties
State: New York
Zip/Postal Code: 12477
I'm currently working on a double cutaway (solid body) project. It was a cheap body I bought. I need some suggestions on how to go about with the neck holes. The heel is cut away and so one of the holes has been drilled in closer. I have found a neck plate on amazon that might do the job but its being shipped from china and it says its going to take about a month to get here. I also have bushings that I could possibly use. Anybody have any other suggestions or any advice?
 Post subject: Re: neck holes
PostPosted: Thu Mar 27, 2014 7:43 pm
First name: D
Last Name: S
I think Stewmac has some ferrules that are used under the screw heads withou using a plate.
Part number 4184
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Mar 29, 2014 1:04 pm
First name: mark
Last Name: funk
City: cooper city
State: fl
Zip/Postal Code: 33328
the bottom holes look wider in that pick, if so you have no choice but to use bushings....
something like this would work:
http://www.ebay.com/itm/Guitar-Neck-DIY ... 3f2f3f947f
or you can just buy some neck screws & see if the local hardware store has some kind of ferrules...
https://www.facebook.com/Funkguitarsusa
