It is currently Wed Jul 23, 2025 2:34 pm
 Post subject: Zero'th fret questions.
PostPosted: Mon Nov 04, 2013 2:16 pm
First name: Kristoffer
Last Name: Eide
City: Ankenes
State: Nordland
Zip/Postal Code: 8520
Country: Norway
Hello again! The neck-through i got help with in another threat is really coming along :) Now i have a question about a zero fret, that i hope you could help me with. The reason i want a zero fret is that i have no guitars of this kind, and i was really surprised when i tried the ones i have tried with a zero fret.
Ok, so
Do i use the same fret size on the zero fret?
Do i use a different radius on the zero fret?
How can i make sure i get the same amazing low action in the construction stage, if there are any small but important tips here.
How far back from the zero fret can i place the nut/string retainer?
Thanks in advance!
PostPosted: Mon Nov 04, 2013 2:54 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Zero fret should be the same as all other frets. You level and crown it just as you would all other frets on the FB.
The "nut", which is regulating the string spacing, can be quite close to the zero fret (as little as 2 mm), but be aware the narrow piece of wood between the zero fret and end of the FB can easily snap off when you insert/press/hammer in the fret. The closer is the nut to the fret, the more careful you need to be. You can file down the barbs on the tang for an easier fit and maybe a bit of glue.
Personally, I like zero frets, but many clients prefer a nut, even if it's plastic.
PostPosted: Mon Nov 04, 2013 3:40 pm
Last Name: Eide
City: Ankenes
State: Nordland
Country: Norway
Thanks, so im guessing the string action is regulated by the bridge and truss rod? Makes sence actually, as strings ring on all frets (or should ring:) )
Thanks alot!
The "nut" space from the zero; how far away can it be before its a problem. I have this idea of having slots in the break angle neck/headstock where the strings pass through on their way to the tuners, and this means i have to have the nut about 1,2 cm (just under 1/2") away from the zero fret. Will this cause the string to jump of the neck do you think?
PostPosted: Mon Nov 04, 2013 4:03 pm
City: chicagoland
State: illinois
by the way....a properly set up nut should have action that is every bit as low as a zero fret....it just takes more care to do so
PostPosted: Mon Nov 04, 2013 8:26 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I like my zero fret just a bit taller than the others. I would always level and crown and then install the zero so it is maybe .005 that you took off on the leveling higher. +1 on snapping the end of the FB off being easy to do, careful there. Tremolos can wear out zero frets pretty quick too.
Brian
PostPosted: Mon Nov 04, 2013 9:13 pm
First name: duh
Last Name: Padma
Do i use the same fret size on the zero fret? Yes
Do i use a different radius on the zero fret? No.
How can i make sure i get the same amazing low action in the construction stage, if there are any small but important tips here. Question does not compute. Please reenter.
How far back from the zero fret can i place the nut/string retainer? As far as you want.
PostPosted: Tue Nov 05, 2013 2:29 am
Last Name: Eide
City: Ankenes
State: Nordland
Country: Norway
Thank you for all your answers!
