It is currently Wed Jul 23, 2025 8:33 pm
 Post subject: Neck through neck angle
PostPosted: Sun Oct 06, 2013 3:20 pm
First name: Kristoffer
Last Name: Eide
City: Ankenes
State: Nordland
Zip/Postal Code: 8520
Country: Norway
Hello! I´m new here, so if my question has been answered elsewhere (I could not find it) please direct me there. Also, for answering, links will do for me :D
I am building my first neck through. I have built a couple of strats, and a tele (bodys only), but now I have received the woods from my local lumber salesman. I have now encountered a the neck angle issue. I´m thinking about using a wrap around bridge, and want to know if there is some kind of online recource or calculator for determening the neck angle. I have tried to determine this by using a straight edge, but i cannot get a clear measuring with my degree-dial (?) as I have not yet startet to plane the neck since im worried about taking too much of.
Any help is well appreciated :D
Kristoffer,
Norway
PostPosted: Mon Oct 07, 2013 11:11 am
verhoevenc wrote:
Draw out a full scale drawing. There are other methods and calculations you can use, but doing this at least once will be great to not just teach you how to do it, but also how to understand the 'why' questions associated with it.
Chris
+1000.
I made the mistake of not doing this on my first guitar. I never made that mistake again. Each time I build something new, the first step is to draw it all out full scale so that I know what I need to do before I start.
Best advice I was ever given, and like a lot of first timers, I ignored it at my own peril.
PostPosted: Mon Oct 07, 2013 12:28 pm
Last Name: Eide
City: Ankenes
State: Nordland
Country: Norway
Thanks! I actually have it drawn out, but it did not occur to me that I could measure it there. Thanks again :)
PostPosted: Tue Oct 08, 2013 11:01 am
First name: Freeman
Last Name: Keller
I'll add two quick comments - first you can get all of the dimensions for your bridge, tailpiece, pups, and even frets from someplace like StewMac - look for the "specification" tab. Second, if you use a drafting program like AutoCAD it will give you the angle very accurately - you can actually draw your frets, nut and bridge action heights, and the software will tell you the angles. Take that one step farther and plot the neck to body joint, cut it out and glue it to some cardboard and you have a template for cutting the angle.
PostPosted: Sat Oct 19, 2013 11:12 am
First name: Wes
Last Name: Richards
City: Livonia
Zip/Postal Code: 48152
i have just completed the same thing you are trying to do ,i bought all my parts first so i knew specificly what i had i drew out every possible aspect i had i used a schroder stop tail piece ,and jasen has been more then help full when answering questions ,as whith this forum,get the book by melvyn hiscock it is very help full by the way i came out whith a 3 degree angle for a 623.88 mm gibson scale.
