It is currently Sun Jun 29, 2025 11:55 pm
 Post subject: Fender Fat Strat
PostPosted: Wed Dec 10, 2008 10:56 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I would like to build one. Where do I get the plans/pattern?
 Post subject: Re: Fender Fat Strat
PostPosted: Wed Dec 10, 2008 11:30 am
First name: Erik
Last Name: Hauri
State: Maryland
http://guitarbuildingtemplates.com/
The neck-body joint is at the 16th fret. There are many ways to rout for the pickups, depending on whether or not you choose to use a pickguard.
If you're putting a fancy top on it, rout some wire channels in the body before you glue the top on.
The member formerly known as erikbojerik....
PostPosted: Wed Dec 10, 2008 1:03 pm
Last Name: Cyr
City: Roseville
Try looking in Fender's Mr Gearhead website:
http://www.fender.com/support/wiring_di ... _lists.php
The diagrams are in pdf format, and you'll have to scale them to the correct size. You can use the fact that the Strat's scale length is 25.5 inches to do the scaling.
Another approach is to get a set of templates from this Ebay seller:
http://cgi.ebay.com/Luthier-guitar-buil ... 0293246604
Good luck!
--Steve in Roseville
---Steve
PostPosted: Wed Dec 10, 2008 10:36 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Erik, Thanks for that tip! Thats the way to go!
