neck angle issues http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10122&t=20121 |
Author: | Tai Fu [ Sat Dec 20, 2008 8:47 pm ] |
Post subject: | neck angle issues |
On my first build I am having issues with the neck angle. if I angle the neck flat and not following the angle on the upper bout then everything lines up. However if I attempt to angle the neck to match the upper bout then the straight edge will sit too high off of the bridge (which will require a very tall saddle to have workable action) however the problem is if I don't match the upper bout then there will be a gap between the fretboard extension and the soundboard. I think next time I will not sand the upper bout so much in the radius dish to avoid this problem in the future.... The problem is the only way that I can see to bring the action to usable level while matching neck angle to the upper bout is to shave the fingerboard or something or make a really big bridge. The gap is only visual (I hope) so I don't think playability is an issue... but it just looks so dammed ugly that you can see daylight through the fretboard extension and see the tenon and stuff... |
Author: | R W Goodman [ Sun Dec 21, 2008 5:28 am ] |
Post subject: | Re: neck angle issues |
If I understand your problem correctly I think you might take a look at Hesh's tutorial about truing the upper bout. Seems to relate directly to what your problem is. Its in the archive of tutorials. Warren. |
Author: | Andy Birko [ Sun Dec 21, 2008 6:47 am ] |
Such short memory spans ![]() viewtopic.php?f=10122&t=19963 I planed the top flat some and sanded the bottom of the FB extension some and now everything works out perfectly. Good luck. |
Author: | Hesh [ Sun Dec 21, 2008 7:58 am ] |
Good Job Andy!!! ![]() ![]() ![]() ![]() ![]() ![]() Tai Fu the taller bridge is a long walk down a short pier. Instead look at Andy's thread from last week and let us know if you have any questions? |
Author: | bluescreek [ Sun Dec 21, 2008 12:32 pm ] |
The understanding of the geometry of the top is key. The more you build the more you learn. http://bluescreekguitars.com/blog/ this link may help you understand one of the many techniques to get the sides to help the top accept the geometry . john |
Author: | Tai Fu [ Thu Feb 26, 2009 3:17 am ] |
Post subject: | Re: The R4(R4DS) Cartridge |
So the cartridge sits in the neck pocket or heel which raises neck angle?? |
Author: | Michael Dale Payne [ Thu Feb 26, 2009 3:35 pm ] |
Tai Fu wrote: So the cartridge sits in the neck pocket or heel which raises neck angle?? Cartrige??? |
Author: | Eddie Lee [ Sat Mar 07, 2009 2:14 pm ] |
Help!!! I can not get to Hesh's tut on Dome leveling anymore. I was at http://luthiersforum.3element.com/pages ... ng_jig.htm . That is a great write up! |
Author: | Ricardo [ Sat Mar 07, 2009 4:44 pm ] |
John, without the head and tail blocks in don't the sides flex a lot when you are sanding? Is the pipe placed half way between the top end and bottom end of the body or at the highest point of the sides? |
Author: | Lillian F-W [ Sat Mar 07, 2009 5:32 pm ] |
Eddie, I might have saved a copy of Hesh's tutorial on my home computer. I'll look when I get home. In the mean time you might be able to glean what you need from this thread. http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=20177 |
Author: | Lillian F-W [ Sun Mar 08, 2009 12:15 pm ] |
Eddie, I dug through my archived web pages and unfortunately that was one that I didn't grab. Sorry. Hope the other link helps. |
