It is currently Fri Aug 22, 2025 3:02 pm
PostPosted: Tue Nov 12, 2013 10:53 am
First name: Caleb
Last Name: Buuck
Hey guys, I've glued my book matched backs together and though it is a strong and right bond I would still like to glue on the inside bracing strip down the middle. I don't have any extra spruce what's the next best thing that I good possible get from a home department store? Thanks for the help!
PostPosted: Tue Nov 12, 2013 11:53 am
First name: Freeman
Last Name: Keller
The grain on center seam bracing runs at right angle to the grain of your back. You can rip if from spruce, mahogany or Spanish cedar and while it is nice to have it long enough to do the entire seam (you then notch it for the braces) that isn't completely necessary - you can cut shorter piece that just fit between the braces. I like to match the braces - if I'm using mahogany then I like the seam to also be mahogany.
However StewMac, LMI and most other lutherie supply houses sell it - why not just order a piece of the good stuff.
Lastly, there are some builders who do not brace this seam and it seems to work fine.
These users thanked the author Freeman for the post: OneBearman (Tue Nov 12, 2013 12:00 pm)
PostPosted: Tue Nov 12, 2013 12:21 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
There's usually enough extra length in the top to cut a couple of 3/8" strips across the grain.
PostPosted: Sat Nov 16, 2013 11:54 pm
First name: Tony
Last Name: C
City: Brooklyn
Use the off cuts from the back. It looks excellent, especially if you sand it nice and smooth and put a little finish on it.
http://www.CostaGuitars.com
PMoMC
These users thanked the author Tony_in_NYC for the post: Nick Royle (Sun Nov 17, 2013 8:50 am)
