Cut this into acoustic wood or electric http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10117&t=40969 |
Author: | Chris Pile [ Thu Jul 25, 2013 12:43 pm ] |
Post subject: | Re: Cut this into acoustic wood or electric |
Being a solid body guy.... I think I could safely say BOTH! |
Author: | turmite [ Thu Jul 25, 2013 12:49 pm ] |
oops seems like I missed the forum I intended to place this in. Mike |
Author: | the Padma [ Thu Jul 25, 2013 7:26 pm ] |
both! nix the bridge. |
Author: | cphanna [ Thu Jul 25, 2013 7:51 pm ] |
Yes...both. Enough said. |
Author: | twick [ Thu Jul 25, 2013 8:11 pm ] |
I'll take strat sized slab please. ![]() |
Author: | Kevin Waldron [ Fri Jul 26, 2013 2:17 pm ] |
Ash will stain very easily while drying. ( sticker stain, mold, mildew, etc. ) I'd try and find a vacuum kiln to dry this stock if your going to leave it in thick portions. Very nice material to let stains ruin all of it. Blessings, Kevin |
Author: | turmite [ Mon Aug 12, 2013 4:32 am ] |
update on the wood. I finally got to go look at the log on Friday. Sad to say the least. I discovered that this log was actually the butt cut of a total of three logs and the bottom log was indeed about 3 ft at the cut, a little over 9 ft in length and about 30 inches at the small end. The thing is, it had been laying in the elements and sunlight for over two years. I have only know about it a few months and thought it was fresh cut. The bark as slipped on the tree and you can see the curl in the wood that is showing. There is a chance I can get a 1/4 log cant that is not split all to pieces. When I bust it open I will know immediately. Otherwise, I am going to have hundreds of linear feet of binding material that is intensely curled. I hope to get the log broken up and delivered to my shop this week. Now my question. If the 1/4 log is still intact, what length do I cut the billet sections to for sides, binding and backs? If all I have is binding, what length do I cut to? Mike |
Author: | cphanna [ Wed Dec 18, 2013 9:31 pm ] |
Well, based on the pictures, all I can say is there is still good wood in there. Cut off the end checking (I see a fair amount of it in the billets). Get rid of any bark that might remain. Stack your planks well stickered. And...because of the tendency to show sticker marks, re-stack your planks every month or two and move the stickers to a different location. Season it well. Then cut some for acoustics and look for some you can hold out for solid body "show" wood. |
Author: | turmite [ Thu Dec 19, 2013 10:21 am ] |
Nothing sly about me......just dogged determination. I fought with the cnc machine fix for ages until I finally made the decision that "duh......I had already replaced half of the components on the machine, I will just fix it by replacing all the others!" Hey, it worked!!! Never did nail down exactly what the issue was. It would come, and it would go but it has been working very well on the tests I have run. Chris, I think I am going to have more wood that I originally hoped for after seeing how bad the log was. I am going to clean me a place in my storage bin, to stack and sticker this and then in 3 months check the m/c. I may even build a little solar kiln to take this on down to a better m/c. If anyone close to Arkansas has access to a quality hardwood kiln and someone that knows how to run it, let me know. Mike |
Author: | ChrisC [ Thu Dec 19, 2013 11:16 am ] |
PM sent. Hope the info helps. That is very nice ash! chris |
Author: | dzsmith [ Thu Dec 19, 2013 7:54 pm ] |
verhoevenc wrote: Bear in mind folks this isn't swamp ash. That doesn't deter ya'll? I know Fender made some hard ash P-basses in the day but I was under the impression they were not the desirable ones? I'd love to see this be more acoustic sets. Hopefully Todd will chime in and show a picture of his build that he's using some on right now. Chris I read Fender made about 100 Strats out of Hackberry, so I'm sure any kind of Ash would be just fine, but yeah, it would look more pleasing on an acoustic than a solid body (larger surface). |
