It is currently Sat Jul 19, 2025 9:07 am
 Post subject: fret find 2d
PostPosted: Sun Oct 13, 2013 2:33 am
For anyone that doesnt know this is a site that you can choose the scale and then print the fretboard slots! I would like to ask something about this...i am building a 36 cm scale baglamas(greek intrument) the problem ii have is where to cut the first fre meaning where the nut goes...before the line or on the line?i measured the distance from the first fret to the 12th and from the line it is les than 18cm something like 17.9 before the line it 1 mm before the line it is 18...i will show you what i mean in the photo above
 Post subject: Re: fret find 2d
PostPosted: Mon Oct 14, 2013 8:20 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
The definition of a line is that it connects 2 points and has no width, So the answer to your questions is yes and yes. The other lines represent the center of the fret so you cut so that those lines are centered.
PostPosted: Tue Oct 15, 2013 11:30 am
Thanks alot man!So i will cut it on the line !
PostPosted: Fri Oct 18, 2013 1:49 pm
Last Name: Moore
City: Nacogdoches
State: Tx
Zip/Postal Code: 75965
Picolo, are you checking that the scale printed correctly? Sometimes printers can slightly shrink or enlarge what it prints.
Just in case.
Bob
Bob
From the oldest town in Texas.
PostPosted: Sun Oct 20, 2013 5:42 am
naccoachbob that is what i thought abou because only the first fret(i mean where we cut the fretboard for the nut)was 1mm incorect when i added one milimetre to the nut slo9t then alla the fingerboarrd was correct so what i thought is if the program thinks that the spot where the strings meet the string isnt the same that they (strings) actually sit on it...am i thinking correctly? I will show you in a picture what i mean. Also after i did that alla other measurments from the spot the strings sit are correct
