It is currently Fri Jul 18, 2025 7:21 pm
PostPosted: Sat Oct 08, 2011 10:02 am
First name: Big
Last Name: Jim
I built this from a coffee can as you can see , I made it from stuff I had Lying around . The vibratory motor was out of a old sand blast cabinet . This particular motor is kinda expensive , however I think a cheaper unit could be had .
Anyway , I mount it in two holes I have drilled in a table and just set it in on the vibe pegs and let it sit , if its clamped it stops vibration and you dont want that . Put media in and some cleaner and turn it on .
In the bottom of the can you can see I forced a lid down in there . I put silicone in the bottom and forced lid down over it to help control leaks from cleaner . The media only needs to be wet , you dont want liquid standing .
PostPosted: Sat Oct 08, 2011 11:53 am
First name: Jim
Last Name: Hansen
Awesome!, Thanks Wud!
Jim Hansen
