It is currently Fri Jul 18, 2025 7:21 pm
 Post subject: Carving a Pyramid Bridge
PostPosted: Wed Sep 21, 2011 6:57 pm
Last Name: Killin
A while back there was a thread posted asking how people go about making pyramid bridges. There is a ton of good information in that thread.
viewtopic.php?f=10101&t=31094&hilit=Pyramid+Bridge
I was just about to start jigging up to make a pyramid bridge when the thread was started. One of the posts mentioned Frank Ford’s site where he shows how he makes them.
http://frets.com/FRETSPages/Luthier/Tec ... ridge.html
After reading Frank Ford’s instructions, I pretty much followed that. It was easier to do that than it would have been to make the jigs. However, I do not have one of the sanding belts he used to cut the pyramids. In place of the sander, I used files. In many ways this is just a recap of what I did to follow Frank’s guide with adaptations for tools I had available.
I’m using a Brazilian Rosewood blank that that came from Singgly’s stash.
I dimensioned the blank on my table saw. I used a plane to true up the edges and flatten the bottom. I’m finding that as I get better with the hand tool I’m using them more.
I marked out some reference lines on the blank.
PostPosted: Wed Sep 21, 2011 7:01 pm
Last Name: Killin
To create the radius I used a 7/32” Chainsaw file to cut most of the material away. I really like the chainsaw file. It is a consistent 7/32” for its length and doesn’t taper to a point. It cuts fast and leaves a smooth edge. Frank Ford used a 3/8” file but I couldn’t find one and improvised. I opened the groove up with a 3/8” wooden dowel wrapped with 100 grit sandpaper to finish it off.
PostPosted: Wed Sep 21, 2011 7:03 pm
Last Name: Killin
I then used a file to cut the angles at the ends of the blank.
I clamped the blank in my vice with a wooden block on top.
The block did two things. First, it kept the file from drifting too far back into the bridge. I was careful but this was helpful. Second, I also drew a line on it with the approximate angle I was going for with the sides of the pyramid.
The goal was to cut at this angle up to the center line in the top and down to the line I had drawn at the bottom edge of the blank.
PostPosted: Wed Sep 21, 2011 7:07 pm
Last Name: Killin
I worked on one side of an end until it hit the center line. I then did the other paying attention to not move the center line by over filing. This will end up being the point of the pyramid. I also was careful as I was doing this to also watch the lines where the end triangle was formed, making sure that they were straight and met at the squared ends of the blank. I did goof up and somehow damaged one corner. I was able to make it less visible by slightly adjusting the line. It still works but I’ll know I did it. Watching the lines form is a good way to tell where you need to remove material.
The next step is to cut the back side of the pyramid. As you can tell from the previous steps I like using guide lines instead of just winging it. To mark the guide lines for the last section of the pyramid, I took some tape and followed the lines made by the triangle at the end of the bride. I’m sort of carrying those lines over the mountain (pyramid) and into the groove.
I then drew the line on the bridge following the tape
The key here is to make them uniform. My intent is for the inside corners of the pyramid to terminate at the bottom of the groove.
PostPosted: Wed Sep 21, 2011 7:11 pm
Last Name: Killin
I used a flat chainsaw file to file this side. The edges of the chainsaw file are smooth, so that add a bit of protection if the file slips.
File down to the lines keeping an eye on the point. At this time I used the lines as a guide to see if I was filing too aggressively.
I added some pencil to the side as I was working so I could see where I was taking off material.
Here I have the 4 sides of the pyramid complete. You can see where I nicked the corner of the bridge.
(17 Bridge inside Cut Final)
Next I start smoothing out the transitions on the bridge between the pyramid and the groove.
PostPosted: Wed Sep 21, 2011 7:14 pm
Last Name: Killin
I use the wooden dowel wrapped in sandpaper here to work this part down.
I am targeting blending it down to the line at the base of the pyramid.
For this bridge I wanted to end up with that rounded back. I used the flat chainsaw file to do the bulk of the work here.
I marked the areas where I was working to blend out the lines so I could track where I was actually filing.
PostPosted: Wed Sep 21, 2011 7:16 pm
Last Name: Killin
It doesn’t take much here to get nice blend. I’m working to remove the strong back line of the pyramid while leaving a smooth transition to the sides. I was careful at this stage not to move the point of the pyramid. I did a light sanding to remove any file marks left behind.
Here is the final result. The bridge weighs in at 22g.
These users thanked the author John Killin for the post: jackwilliams (Sat Sep 21, 2013 7:08 pm)
PostPosted: Wed Sep 21, 2011 8:15 pm
City: Jacksonville
bliss [:Y:] [:Y:] [:Y:] [clap] [clap] [clap]
YOU GO JOHN!!!!! Fantastic! I love it. I know who to talk to now when I need a pyramid bridge my friend...you should never have posted this...... laughing6-hehe laughing6-hehe
PostPosted: Sun Sep 25, 2011 10:47 pm
First name: Aaron
Last Name: Craig
State: Missouri
Thank you! I will soon be needing to make a few of these and have been trying to figure out how best to do it. This should help immensely.
Aaron Craig
PostPosted: Sun Sep 25, 2011 11:15 pm
AWESOME tutorial, John! [clap] Thanks very much for posting it. Now I know what to do with the beautiful blanks I got from Sniggly. [:Y:]
