It is currently Thu Jul 17, 2025 11:42 pm
PostPosted: Sat Aug 08, 2020 12:32 pm
First name: Rick
Last Name: Hubka
City: Chemainus
State: BC
Zip/Postal Code: V0R 1K1
Hi
I'm making a few dozen pickguards of different colors and with my CNC all cuts are great except the outer edge bevel with a 90 degree V-Bit. I have tried several different 90 degree-V-Bits with no change. I install all 8 pickguard screws to hold it down.
For straight cuts I use a special plastic cutting bit that works great
Feed Rate 55 inches/min
RPM 7000
Faster RPM starts to melt the material.
I even tried repeating the last cut at the same and faster RPM. Sanding the edges takes a ton of time and is not easy on tight turns.
This image is right next to a screw.
Any advise?
Rick Hubka
Chemainus BC Canada
PostPosted: Sat Aug 08, 2020 3:32 pm
City: U.P.
Is it screwed down flat with 100% support against a spoil board? Looks like the bit is forcing the edge down causing it to bounce or vibrate under the cutter when the cutting edge hits the pick guard.
Brian R, Wood Mechanic
N8ZED
PostPosted: Sat Aug 08, 2020 5:12 pm
First name: Rick
Last Name: Hubka
City: Chemainus
State: BC
You are right. The small screws 2 to 5 inches apart do not provide 100% flat support to the somewhat flexible plastic. I am going to make an aluminum hold down plate. TKS!!!
I did slow down the Feed Rate from 55 to 30 inches/min and it was a small improvement.
I'll post back after making a hold down plate.
Why do all these small simple projects always turn out more complicated? LOL!!!
Rick Hubka
Chemainus BC Canada
PostPosted: Tue Sep 22, 2020 11:15 pm
First name: Rick
Last Name: Hubka
City: Chemainus
State: BC
Hi Guys.
Sorry for the slow response...
Well... I now have a fairly smooth pickguard edge on my pickguards. I doubt that many people hold down that floppy pickguard material better than me now. :lol:
1/8 inch aluminum plate hold down templates!!! Overkill. Maybe???
Here's a picture.
Rick
Rick Hubka
Chemainus BC Canada
