Making a CNC neck on my shopbot http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10106&t=26471 |
Author: | John How [ Wed Mar 10, 2010 10:41 pm ] |
Post subject: | Making a CNC neck on my shopbot |
Here is my second attempt at making a neck on the bot. The first worked out fine, i just forgot to take pictures. I do need to clean up my referencing as I flip the neck to do each side. I do it this way because I don't have enough Z travel to just clamp the thing face down. My goal is to make a slightly oversized blank that I can custom shape quickly with the pneumatic drum sander. I think I am just about there as this cleans up real fast and has just enough meat for me to make adjustments as the customer wants. Here is a quick video and a couple pics. ![]() ![]() ![]() |
Author: | cyborgcnc [ Thu Mar 11, 2010 9:11 am ] |
Post subject: | Re: Making a CNC neck on my shopbot |
Nice work! That did come out great... Why did you choose to mount it on "it's edge" for machining the neck, versus mounting it flat (fretboard side down)? I think mounting it the other way, would be easier to machine, and also, cut down on a lot of the "air cutting".... Regardless, GREAT WORK! |
Author: | Rick Hubka [ Thu Mar 11, 2010 2:34 pm ] |
Good Job John. What is your Z travel? Nice to see an acoustic neck CNC video. I have seen dozens of video's on electric necks but very few acoustics. ![]() |
Author: | John How [ Tue Mar 16, 2010 7:22 pm ] |
cyborgcnc wrote: Nice work! That did come out great... Why did you choose to mount it on "it's edge" for machining the neck, versus mounting it flat (fretboard side down)? I think mounting it the other way, would be easier to machine, and also, cut down on a lot of the "air cutting".... Regardless, GREAT WORK! I did it this way as I don't have a lot of Z motion and I don't have a long bit either. The air cutting is due to the software I use (the stuff that came with the machine), it doesn't allow anything but a block shape to start with or at least I haven't figured out how to tell it what the starting shape is other than that. It is a fairly simple tool pathing program and I don't care to take the learning curve on for something more complicated right now. |
