Semi Acoustic Resonator Build http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10104&t=41773 |
Page 1 of 2 |
Author: | Freeman [ Sun Oct 27, 2013 11:24 am ] |
Post subject: | Re: Semi Acoustic Resonator Build |
Looks good and interesting. Yes, the usual cone well depth for a biscuit is one inch and the top is flat (no dome). You set most of the action with the neck angle as you have very little adjustment at the biscuit. Most have neck sticks but I've had good luck with my standard bolt on neck - I also bolt down the fretboard extension to make it easy to adjust neck angle. One of the tricky things for me is that you are starting with the bridge location and working back (rather than positioning the bridge last as you do on an acoustic). Decide whether or not you want any compensation now, then position the cone well relative to the scale length and neck block. As you know, most resos aren't compensated but if your client wants to fret it you might consider. Carry on and please keep posting the progress. I'll be interested in what you end up doing for electronics and how it sounds. |
Author: | Marzano San [ Sun Oct 27, 2013 11:37 am ] |
Thanks for the feedback Freeman! Yups I'm going to add compensation as I want to have the intonation as good as possible. He will be fretting strings too. I know it is a wee bit strange to start with the bridge position and work from there. Will keep posting progress, very curious how this one will sound... |
Author: | Freeman [ Sun Oct 27, 2013 2:04 pm ] |
Marzano San wrote: Thanks for the feedback Freeman! Yups I'm going to add compensation as I want to have the intonation as good as possible. He will be fretting strings too. I know it is a wee bit strange to start with the bridge position and work from there. Will keep posting progress, very curious how this one will sound... To compensate or not to compensate.... For slide you don't want any, for fretting you do. However when playing slide you have the ultimate compensator on your pinkie, and frequently you want the note just a hair flat so I would tend to put a little bit in. You can rotate the cone slightly but that brings one end closer to the nut which you don't want. Obviously the higher the action (for slide) the worse it will be too. I have both a wood 1932 Dobro spider and a metal biscuit bridge Duolian - neither have any compensation. When I built my tricone I put a little in and am glad that I did. One of the other things you should discuss with your client (probably already have) is the fretboard radius and width - as a slide player I am partial to a wide board with about 20 inch radius, but an electric player is probably going to want a narrower one with more. Again, another compromise, with a radiused board and lower action you'll get a lot of fretout unless you use a curved slide. |
Author: | Freeman [ Sun Oct 27, 2013 2:11 pm ] |
I'll just add a couple of more thoughts on sound. IMHO the wood body will mellow the sound a lot - when I play my tricone gently it sounds almost like an acoustic, but its got the reso bite when I dig in or use finger picks. Biscuits are usually metal body and we associate that loud nasty sound with sharp attack and delay - I think the wood will take some of that away. The other question is how you will amp it - if you want good reso sound you probably need one of the little internal mics inside the cone well or maybe the one built into the biscuit. I've heard resonators with lipstick or magnetic pups and they sound pretty much like an electric guitar (duh). If it were me and I knew it would be played mostly plugged in I would install both and let the engineer pick the sound at the board. I play unplugged and the few times I gig I just put a mic in front of the grills. |
Author: | Marzano San [ Sun Oct 27, 2013 2:16 pm ] |
Freeman wrote: One of the other things you should discuss with your client (probably already have) is the fretboard radius and width - as a slide player I am partial to a wide board with about 20 inch radius, but an electric player is probably going to want a narrower one with more. Again, another compromise, with a radiused board and lower action you'll get a lot of fretout unless you use a curved slide. Thanks for pointing this out! He's got a National (steel) resonator, I was thinking copying that neck/fingerboard and go for a 25" scale (that's what he wants) I'll double check with him and yes the radius is an important 'item' to discuss. |
Author: | Marzano San [ Sun Oct 27, 2013 2:23 pm ] |
Freeman wrote: I'll just add a couple of more thoughts on sound. IMHO the wood body will mellow the sound a lot - when I play my tricone gently it sounds almost like an acoustic, but its got the reso bite when I dig in or use finger picks. Biscuits are usually metal body and we associate that loud nasty sound with sharp attack and delay - I think the wood will take some of that away. The other question is how you will amp it - if you want good reso sound you probably need one of the little internal mics inside the cone well or maybe the one built into the biscuit. I've heard resonators with lipstick or magnetic pups and they sound pretty much like an electric guitar (duh). If it were me and I knew it would be played mostly plugged in I would install both and let the engineer pick the sound at the board. I play unplugged and the few times I gig I just put a mic in front of the grills. That's why I'm going for a highlander iP-1X INLINE for the cone and use a P90 (un-waxed slightly microphonic) for the magnetic picup. I've ordered a National Slimline Pickup and will A-B test is with the P-90 (a friend of mine is going to wind it) A volume for each pickup and a "blend knob" will be installed |
Author: | Marzano San [ Mon Oct 28, 2013 1:45 am ] |
Almost ready to glue the top on ![]() |
Author: | Marzano San [ Mon Oct 28, 2013 10:17 am ] |
And the top is on ![]() |
Author: | Mike Dotson [ Tue Oct 29, 2013 6:42 pm ] |
Excellent! Different and very well done. I look forward to hearing some sound clips/video. |
Author: | Marzano San [ Wed Oct 30, 2013 1:18 am ] |
Mike Dotson wrote: Excellent! Different and very well done. I look forward to hearing some sound clips/video. Thanks Mike! Sound clips/video no problem. My friend owns a studio and he will make some ![]() |
Author: | Marzano San [ Thu Oct 31, 2013 11:47 am ] |
The binding is on, scraped back and sanded the guitar ![]() Sprayed a washcoat on ![]() |
Author: | Shaw [ Fri Nov 29, 2013 3:15 am ] |
Looking good.. |
Author: | Marzano San [ Fri Nov 29, 2013 4:09 am ] |
Thanks Shaw! |
Author: | Freeman [ Mon Dec 02, 2013 12:07 am ] |
Clips, we need sound clips. But it sure looks sweet. |
Author: | Marzano San [ Mon Dec 02, 2013 3:07 am ] |
Freeman wrote: Clips, we need sound clips. But it sure looks sweet. I'll record some after I did the fretwork. Also going to put an ebony cap on the bridge. |
Author: | Marzano San [ Wed Dec 04, 2013 10:13 am ] |
Freeman wrote: Clips, we need sound clips. But it sure looks sweet. Still fiddling about with the cone pickup, still not happy with it. Again, still have to do the fretwork as they are still not leveled... ![]() Anyhow here is a sound clip first part is the nanoflex pickup second is the p90 straight in garageband using this crappy classic blues amp thing (don't have a proper microphone to record it trough my DC-30 third part is the nanoflex+P90 straight in a DI recorded with garage band. Please don't judge my playing skills I'm not a player but a builder... Anyhow, like I said, heading in the right direction but not quite there... |
Author: | Mike Dotson [ Thu Dec 12, 2013 3:20 pm ] |
The piezo sounds about like most of 'em do without a lot of buffering (ie, pre-amp and EQ). They rarely sound very full through a regular guitar amp and will sound best through a PA or acoustic amp. Overall I'd say you're on the right track. |
Author: | Marzano San [ Fri Dec 13, 2013 3:17 am ] |
Mike Dotson wrote: The piezo sounds about like most of 'em do without a lot of buffering (ie, pre-amp and EQ). They rarely sound very full through a regular guitar amp and will sound best through a PA or acoustic amp. Overall I'd say you're on the right track. Yeah, personally I don't like the piezo sound that much. I ordered a "plate transducer" and going to try the K&K style pickup. I pore filled the guitar and starting to spray next week (hope the finish arrives in time) |
