Equipment for sale http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=39690 |
Author: | Hank Mauel [ Tue Mar 12, 2013 4:52 pm ] |
Post subject: | Equipment for sale |
The following "package" will probably only be of interest to West Coast luthiers (CA, WA, OR, NV) due to size and weight. I can probably be enticed to deliver it on the West Coast for some gas money and a good burger. Please PM me with your email address for detailed photos as they are too large to fit on the OLF. Also, any questions via PM. Thanks SCM MiniMax Wide Belt sander 25x60" belt. 3 Phase power, but I have.... Kay Industries Rotary Phase Converter Switch gear for the phase converter 100 Amp Cutler-Hammer circuit breaker Approx 35' of heavy gauge wire from breaker panel to phase converter Manuals, parts lists and some spare fuses plus a couple of belts. This system will run on basic 220V house power if you do not have 3 phase available. The 100 amp breaker feeds the first switch box. It activates the phase converter, which switches through the second switch box to provide 3 phase power to the wide belt sander. The sander has it's own on/off switch, sanding belt on/off switch and 2 speed table belt. The sanding belt uses pneumatic pressure belt tension during the sanding process. The table is manually controlled for sanding thickness. Weight is approx 1500 lbs for the sander (you can see it is about the size of a refrigerator) and 200+ lbs for the phase converter. This machine is "low mileage", having been used only by myself and the late Lance McCollum. We have sanded sides, jointed backs and tops (with or without rosettes installed), binding, headstocks (with an auxiliary holding tray), stock for bridges, fingerboards, braces, trued neck blanks...just about anything you need sanded in luthiery, we have sanded. The entire package is priced at $4,000. |
Author: | Don Williams [ Fri Mar 15, 2013 7:12 pm ] |
Post subject: | Re: Equipment for sale |
What every home shop needs! (where's all the Koa???) ![]() |
Author: | Hank Mauel [ Sat Mar 16, 2013 3:37 pm ] |
Don Williams wrote: What every home shop needs! (where's all the Koa???) ![]() Once you have a wide belt, you never go back! ![]() I think that old photo had some darker koa used when I "staged" the shot. Good call! Hank |
Author: | Don Williams [ Sat Mar 16, 2013 4:28 pm ] |
No no Hank! I meant, "Where's the Koa that you're going to sell at the Swap-a-palooza?" ! ![]() But I'd die to be able to have room for & be able to afford a sander like that. Alas, my basement won't fit it and my checkbook can't pay for it! |
Author: | Hank Mauel [ Tue Mar 19, 2013 11:07 am ] |
Oh...THAT koa.... |
Author: | ChuckH [ Tue Mar 26, 2013 9:48 pm ] |
Hank, if you still have the sander it give you $50 bucks for it if you'll throw in free shipping. Deal? Sent from my walkie talkie using Tapatalk |
Author: | Hank Mauel [ Fri Mar 29, 2013 12:36 pm ] |
ChuckH wrote: Hank, if you still have the sander it give you $50 bucks for it if you'll throw in free shipping. Deal? Sent from my walkie talkie using Tapatalk OK, Chuck...here's the $50 version. ![]() I await your "check in the mail"...... |
Author: | ernie [ Mon Apr 01, 2013 3:16 pm ] |
Chuckie at those prices you better start makin deals with the nigerian spammers, who always have a check in the mail ![]() |
