om sides? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=14794 |
Author: | leerobs42 [ Mon Dec 03, 2007 10:12 am ] |
Post subject: | |
hey all, at the risk of showing how novice i am at building guitars i started on an om (martin style, based on the martin plan from stewmac) project a couple of years ago and recently picked it up again. i purchased the back and sides from lmii and i can't remember the measurements that the sides need to be before i start bending. ![]() ![]() |
Author: | TommyC [ Mon Dec 03, 2007 10:42 am ] |
Post subject: | |
Hey leerobs42 (Lee?)! I am building an OM now but from a slightly different plan. It is 4" at the tailblock, and the sides are somewhere near 32", so 4 1/2" by 34" or so should be in the ballpark. Do you not have a set of plans? If you have a set add some allowance to the finished dimensions. If not, you need some! Good luck. |
Author: | FishtownMike [ Mon Dec 03, 2007 11:12 am ] |
Post subject: | |
If you have the pans take a cloth tape measure like the tailors use and measure the sides of the plan and add a couple inches to the final length to be safe. |
Author: | leerobs42 [ Mon Dec 03, 2007 11:27 am ] |
Post subject: | |
sweet.....what about the height of the sides? it tapers from top to bottom doesn't it? or was it 4" at the neck and 4'1/2 at the bottom? thanks, brandon. |
Author: | leerobs42 [ Mon Dec 03, 2007 11:28 am ] |
Post subject: | |
nevermind.....thats listed on my plan...thanks again, brandon. |
Author: | BruceHerrmann [ Mon Dec 03, 2007 11:53 am ] |
Post subject: | |
Looks like you're there but I just measured a 1931 OM, the tail block height (total, from top to bottom including back and sides of course) is 4 1/16, neck block is 3 5/16. Maybe that will help as well. Bruce |
Author: | BruceHerrmann [ Mon Dec 03, 2007 11:55 am ] |
Post subject: | |
Oops, should have read "including top and back" on the readings, wish we could edit these things though I'd probably wear out that feature in a day or so.... Bruce |
