Making bridge pins http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=14543 |
Author: | luthier49 [ Thu Nov 15, 2007 2:34 pm ] |
Post subject: | |
Just thought you`d like to see how I made the bridge pins for my first steel string build. I bought a collet chuck for my mini wood lathe specially for making brige pins. Although the pins were hand turned, I will be making a profile scraper later to turn just the pin heads so I can have that little tiny bead just under the head. To do this by hand I just find too difficult, my eyes aint what they used to be anyway. Here`s the first photo showing some Ebony being rounded to 11mm diameter. The collet I`ll be using in the collet chuck will be a 11mm to 10mm holding capacity. ![]() Here the Ebony is mounted in the collet chuck with the excess extending into the hollow drive spindle. I turned the 3 degree taper at this stage and part it off. ![]() I tested the taper using part of the StewMac slotting jig tool. I wanted the taper of all the pins to lock into this part at the same place so when I come to slot the pins they would all be consistant. ![]() To turn the heads I made a wooden chuck for the collet chuck. This was drilled out using the tailstock and then reamed out by hand with a 3 degree pin reamer to allow the part turned pins to be jam fitted for turning the heads. I was going to drill the heads for gluing an 1/8" plastic dot, but the chuck ran very slightly off centre so I aborted this idea. I shall make a more accurate chuck next time using some nylon material and reaming it out with the reamer held in the tailstock. ![]() Here are the pins getting thier slots cut. ![]() And finally the finished pins. ![]() |
Author: | TommyC [ Thu Nov 15, 2007 2:41 pm ] |
Post subject: | |
Thanks for the post Bob. Must be a labor of love ![]() the few things along with fretwire and tuning machines that I can safely say I will never make. Those look really nice. |
Author: | Dave Anderson [ Thu Nov 15, 2007 2:50 pm ] |
Post subject: | |
Very interesting Bob. They look real nice! Thanks |
Author: | Blain [ Thu Nov 15, 2007 3:46 pm ] |
Post subject: | |
Thanks for taking the time to show this process. They do look great! |
Author: | Barry Daniels [ Fri Nov 16, 2007 8:19 am ] |
Post subject: | |
Why slot them? They work better without slots. |
Author: | Hesh [ Fri Nov 16, 2007 8:30 am ] |
Post subject: | |
[QUOTE=BarryDaniels]Why slot them? They work better without slots.[/QUOTE] Agreed - Perhaps Bob is making these pins for guitars that are not set-up for, nor will they be set-up for, slotless pins? |
Author: | Hesh [ Fri Nov 16, 2007 8:31 am ] |
Post subject: | |
And very nice tutorial Bob - thanks for putting this together for us. ![]() ![]() ![]() |
Author: | joelThompson [ Fri Nov 16, 2007 8:33 am ] |
Post subject: | |
Very nice, I realy want to turn my own pins out of interesting woods like snakewood etc and also some ivory i have. this has given me the impudus i need to take the plunge, Thnaks bob, Joel. |
