Sutherland Welles Wiping Varnish, pt 1.
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=14492
Author:  Ben Furman [ Mon Nov 12, 2007 5:30 am ]
After asking here at OLF about others' varnishing experiences, I went ahead and ordered a quart of Sutherland Welles Wiping Varnish in High Lustre.  At just over $50 shipped, the stuff isn't cheap, but I'd estimate that the quart will easily finish five guitars.  Please note that all of their products within a type are identical except for solvent content.  The high lustre product has the highest solids loading and can be diluted to make any of the other formulations, including the sealer.  S-W doesn't take credit cards.  You call them up, they send you the varnish, and you send them a check.  Simple and friendly.
I'm using the varnish to refinish a project electric with shellac color coats under a Waterlox High Gloss topcoat.  For reference, the Waterlox is an extremely fast-curing, good-leveling, glossy phenolic varnish.  By comparison, the S-W product is about 4 times slower to cure, has a higher solids content, is similarly glossy, and is more transparent - on par with blond shellac.
After repairing a few dings and leveling the Waterlox, my first effort was to brush the varnish straight from the can using a foam brush.  Despite being labeled a "wiping" formulation, it is actually a brushing formula that can be diluted as the user desires.  Compared to the Waterlox, it does not flow out as readily.  Unfortunately, it also doesn't release bubbles very well, so I am left to sand things down and start over with a good bristle brush and a more dilute formula.  More later as things progress.
-Ben
Author:  Jim Watts [ Mon Nov 12, 2007 7:34 am ]
Ben, I'm interested in seeing how all this works out for you.
Good luck with it.
Author:  Philip Perdue [ Mon Nov 12, 2007 7:50 am ]
Ben,
I have no experience with this product but I have used Tru-oil with excellent results. I was taught to apply the Tru-oil in ultra thin coats using a soft cloth (worn t-shirts). Think very thin coats almost like a French polish where the coats build up for the final finish. Once there were enough coats I just leveled with Micro-Mesh. The results were better than I expected using this method. Try applying using this method on some scrap and see what you think.
Philip
