Need Help With Guild Neck Reset http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=14173 |
Author: | Jim Samuel [ Sun Oct 21, 2007 8:35 am ] |
Post subject: | |
I am going to be resetting the neck on a 1973 Guild D40. I have been able to find information about resetting Martin necks and Gibson necks, but nothing about Guild. It has a dovetail neck joint and it appears to be very similar to a Martin joint. Does anyone know if there is anything unusual about Guild neck joints? Do I still use the 15th fret as the access point to get steam into the joint? Is there anything else I should know? Any help will be appreciated. Thanks, Jim |
Author: | Rick Turner [ Sun Oct 21, 2007 8:52 am ] |
Post subject: | |
Uggh. Guilds and Gibsons are a drag to reset because the necks are glued on before finish. There's practically no way to do a reset that looks as clean as original. Add to that tendency for the laminated Guild necks to start to delaminate at the heel from exposure to steam... You may be best off cutting the neck off with a very thin kerf Japanese pull saw or sending it to Frank Ford for his surgeon's bone saw operation. Then you can shave the heel to the correct angle and bolt the neck back on. If it were my job, I'd send it to Frank. |
Author: | David Collins [ Sun Oct 21, 2007 11:14 am ] |
Post subject: | |
Guild neck resets. What fun. Aside from the post-assembly finishing, they often have that massively wide heel glued not only in the dovetail, but heel to shoulders. Why, nobody who understands the mechanics of a dovetail joint has ever been able to figure out. If you steam it off I've found it useful to pop the heel cap to come at the shoulders from behind, as well as steaming the dovetail from through the 15th fret. Like a Gibson, make sure the truss rod is tight and feel the back of the neck while steaming to make sure steam isn't flowing in to the truss rod slot. it will take a lot of heat and steam, finish work, and even with great care and preparation some can be quite difficult to keep the heel in one piece during removal. I charge more for a Gibson than a Martin, and more for a Guild than a Gibson. Occasionally you'll get a cooperative one, but consider that as compensation to make up for the lost time on others. Cross your fingers and hope you got an easy one. If not, the biggest key not to rush it when steaming it off. If it doesn't want to move just keep working steam in from different angles, and try your best to figure out exactly where the dry spots are as it starts to loosen. They're not fun, but if you decide to steam it off it'll give you a chance to be creative with steaming. |
Author: | Jim Samuel [ Sun Oct 21, 2007 11:37 am ] |
Post subject: | |
Thanks Rick and David. I also have to change the bridge on this thing. Jim |
Author: | David Collins [ Sun Oct 21, 2007 11:58 am ] |
Post subject: | |
The bridge should be pretty straight forward hide glue for a '73. I don't know what years (sometime later, perhaps the early 80's), but I've run in to a terrible bridge glue on some. It looks like it could be resorcinol with a blue or purplish color to it, and does not soften with heat or moisture. Those I will sometimes come at with sharp wacks on from a dulled chisel, trying to take advantage of it's inflexibility and weaker impact resistance. There's really no good way that I've found for those, though you shouldn't have to worry about it. Have fun. ![]() |
Author: | Dave Anderson [ Mon Oct 22, 2007 12:10 am ] |
Post subject: | |
I did a 73' Guild Mahog. top and It was a very easy to remove. I got lucky ,this one did not have the heel glued down. Just a little steam thru the 15th fret.The only minor problem was finding the slot under the dovetail to steam. It was so small. I hope yours is this easy Jim. |
Author: | jeffhigh [ Mon Oct 22, 2007 7:27 am ] |
Post subject: | |
Oh dear. I have a '76 F212 Guild 12 string to do at some stage. It is my own that I have had from new, any difference for the 12s. BTW , I already reglued the bridge which had slid forward about 2mm. It had close to 1/4 inch of lacquer unscraped around the edge. |
