lacquer repair on dropped giutar? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=14147 |
Author: | BTucker [ Fri Oct 19, 2007 10:56 am ] |
Post subject: | |
Hey guys, I have a past client who had an accident with his guitar. It was in the case, and picked up with the top unlatched. The guitar fell out of the case
Author: | BTucker [ Fri Oct 19, 2007 11:00 am ] |
Post subject: | |
OK....somehow I posted before I got the other pic up, but it's just another spot below the bridge, and I am on dial up. In reality, most of the dings look like the one on the left. I do think that the one on the right made it to the wood, though. The one under the bridge that I mentioned feels smooth when you touch it...no chip, just a whitish look. OH, and that title should read "guitar" Any Ideas on how to repair this???? |
Author: | BTucker [ Fri Oct 19, 2007 11:03 am ] |
Post subject: | |
I guess I should also mention that it's nitro.....dang.....If I keep up this posting, I'm gonna make Koa in no time!!! |
Author: | Jebarri [ Fri Oct 19, 2007 3:15 pm ] |
Post subject: | |
I don't know if this will help or not but I remembered reading it and thought it might... jrl=221251&utm_source=newsletter&utm_medium=email&utm_campai gn=t s0040&clk=141631">Stew mac trade secrets |
Author: | BTucker [ Sat Oct 20, 2007 12:10 am ] |
Post subject: | |
Thanks , Jebarri and Todd. I had seen the StewMac ad and it sparked the idea, but I think that there was no delam issue in that particular incident. I will probably attempt to remove the fractured lacquer, as you suggest, Todd, and drop fill the areas. I just wanted to ask before I did it, just to be sure I'm not missing something that may work better. Thanks for the info. |
Author: | Doug-Guitar-Buckler [ Sat Oct 20, 2007 6:15 pm ] |
Post subject: | |
I hate to admit it, but I did the very same thing to a Martin d15 one time. It put a dime sized dent in the top. You can definately fix that, will probably take a few coats with buffing in between each coat. |
Author: | BTucker [ Sat Oct 20, 2007 11:37 pm ] |
Post subject: | |
Todd, Thanks for the advice. I went in and picked out the chipped and delaminated nitro...just broke it out like glass, and softened the area with a little acetone. I have started the drop fillings. I am going to have the guitar for a while, as the owner said he was in no real rush, since he has another of my guitars. After I get the build on the fills up, I'll take your advice and let it sit around for a while and cure well, before leveling and finishing up. Once again, thanks. |
Author: | Barry Daniels [ Mon Oct 22, 2007 8:06 am ] |
Post subject: | |
Are you sure that is lacquer? The whitish appearance and the description of breaking like glass sounds more like polyester. |
