Tru Oil Update http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=13931 |
Page 1 of 2 |
Author: | Dave-SKG [ Mon Oct 08, 2007 12:55 am ] |
Post subject: | |
I decided that since I was spending the time to spray Nitro on the Drop Top I would try the Tru Oil on the neck. I really like this STUFF! It cleans easier than Shellac and is building a really nice finish. At first i was using a rag to apply it. I have switched to the finger, rub -in technique as per AL. I can't wait to see it two weeks from now after it's really hardened up. I think this is gong to be my new neck finish. I always F.P.'d my necks, but recently on a Peruvian Black Walnut neck had problems of the FP getting milky after the player played the guitar for a while. It looked beautiful while being FP'd but later had problems...I am not sure if it was because the FP went bad or I didn't wait long emough for it to harden...just don't know. But I do know that the TruOIl seems to be a great way to go and doesn't seem like that is going to be a problem here ( on This BPW neck). Thanks Again Al and everyone for all your input. p.s. does anyone know if i can TruOIL over Shellac? I was considering doing so as a remedy on the problem neck. I hate to sand off all that Shellac if I don't have to. |
Author: | Kahle [ Mon Oct 08, 2007 1:20 am ] |
Post subject: | |
Dave I tru-oiled the neck on an OM cutaway I recently built for a local player. It has been 6 months so far and is holding up fine. I applied it over the shellac and there have been no problems as of yet. K |
Author: | JJ Donohue [ Mon Oct 08, 2007 1:45 am ] |
Post subject: | |
Good info, Dave! I've been using alternative finishes on necks for 3 years now. I first tried FP and like Dave, was not as happy with the results. It is far better than Lacquer IMO but the FP requires an occasional sanding and re-application on the worn areas. While this only takes less than an 30 minutes, it nonetheless would require diligence from an owner...something my family recipients would never tolerate! ![]() For the past year I have used Danish Oil on Mahogany necks and really love the feel and toughness. It has required no re-application and remains hard and slick after 1 year of tough play. On one neck, I pore filled with Zpoxy before applying Danish Oil. I plan to evaluate its condition next month and will be able to compare to non-pore-filled necks...stay tuned. BTW...has anyone ever compared results between True Oil and Danish Oil. I assume they are closely related but was wondering if one has any advantage over the other. |
Author: | JohnAbercrombie [ Mon Oct 08, 2007 3:41 am ] |
Post subject: | |
[QUOTE=Dave-SKG] I hate to sand off all that Shellac if I don't have to.[/QUOTE] Dave- I've had good luck removing shellac by laying paper towels wetted with alcohol over the area for a few minutes, then wiping. Lots of fresh wipes and alcohol seem to clean it up pretty well. You do have to be careful about controlling drips. Might be worth a try- especially if you just want to remove the bulk of the shellac before putting TruOil over it. Cheers John |
Author: | Dave-SKG [ Mon Oct 08, 2007 3:50 am ] |
Post subject: | |
Thanks for the tip. That's a good idea. I was thinking along the lines...if I have the pores filled with shellac why throw away all that hard work? But maybe It would be best. Kahle states he's applied it over Shellac and it worked fine. Like others have said almost everything sticks to Shellac. I have a feeling the problem I am having is that the Shellac is old and therefore not drying hard enough and this player has really sweaty hands...the combination is the culprit. So I think I will try your method and remove with the paper towels and then apply TruOil. Thanks! |
Author: | drfuzz [ Mon Oct 08, 2007 5:01 am ] |
Post subject: | |
I have applied Tru-Oil over shellac too, and had no problems doing so, or reports of problems with the finish in the 18 months since. Nice stuff, it was a rush job and I was able to get a decent finish done in 4 days. |
Author: | old man [ Mon Oct 08, 2007 5:03 am ] |
Post subject: | |
Tru-oil works fine over shellac. Ron |
Author: | erikbojerik [ Mon Oct 08, 2007 5:06 am ] |
Post subject: | |
FWIW Tru Oil is closer to a varnish than an actual oil finish. It goes on over shellac just fine. |
Author: | erikbojerik [ Mon Oct 08, 2007 5:08 am ] |
Post subject: | |
[virtual edit] Because Tru Oil penetrates, you'll get more chatoyance out of figured wood if you don't seal with shellac first. [/virtual edit] |
Author: | ballbanjos [ Mon Oct 08, 2007 5:48 am ] |
Post subject: | |
I've used shellac over Tru Oil, Tru Oil over shellac--they both work fine. I like both of them better on necks than nitro--they just have a better feel to them in my opinion. I decide on which to use by how the instrument is going to be used. If it is going to be in bars or outdoors at festivals a lot, I use Tru Oil since it holds up better to alcohol or rain. Otherwise, I use shellac. On necks, I french polish, but I build up a pretty good thickness. It's not like the super thin fp you'd find on a guitar top. I've never had problems with the finish wearing through, even after really heavy playing (and even lots of outdoor festival playing). Same with Tru Oil. I have banjos finished in both materials that have been played very heavily for years and show no more wear than a nitro finish would. Dave |
Author: | James W B [ Mon Oct 08, 2007 9:07 am ] |
Post subject: | |
Dave,Did you use the Tru-Oil sealer first or just the Tru-Oil.I`ll be using it on my current build for the neck and was curious. James |
Author: | phil c-e [ Mon Oct 08, 2007 10:34 am ] |
Post subject: | |
i'm quickly becoming a truoil fan as well. i've just finished two OM's with it. zpoxy as filler on the back and sides, zpoxy 50/50 with denatured alcohol on the neck, and two coats of shellac on the top, then truoil over the whole thing. beautiful stuff, and i kind of like the smell. on the last guitar i applied the truoil with blue 'shop towels' and it worked well - nice that i didn't need to cut up rags as well. i'll use them again. phil |
Author: | jhowell [ Mon Oct 08, 2007 11:04 am ] |
Post subject: | |
Dave-- Glad it worked out well. I'm a fan of Tru-Oil necks and I do put in on with my fingers (usually) over a shellac seal. |
Author: | A Peebels [ Mon Oct 08, 2007 11:17 am ] |
Post subject: | |
I've never used the Tru-Oil sealer. I just apply the oil over epoxy filler or over shellac. Al |
Author: | Kahle [ Mon Oct 08, 2007 11:45 am ] |
Post subject: | |
A good thing about the tru-oil for the necks is that it replicates a satin finish. I am one of those players who prefer a satin finish as the gloss finishes feel sticky to me as I sweat on them while playing. The satin finish just "feels" faster. While a satin finish can be obtained with steel wooling a nitro finish, as time goes on the act of playing the guitar rubs out the finish and glosses it up. The tru-oil finished necks may bring an end to that. I'm getting ready to try one on a tele neck. This brings to mind an interesting question. I have ordered the Best-Decal headstock decals. Anybody tried these with a tru-oil finish. Current plan is to mask the neck and just shoot the headstock and tru oil the back of the neck. (FB is rosewood so it will be masked anyway) |
Author: | A Peebels [ Mon Oct 08, 2007 12:05 pm ] |
Post subject: | |
Tru oil goes over water transfer decals just fine. Al |
Author: | David R White [ Mon Oct 08, 2007 12:32 pm ] |
Post subject: | |
When you folks are using a satin oil finish on the neck, and a high gloss on the body do you do the entire neck in satin/oil, including the headplate, and heel cap? I'm going to try my first oil neck and wonder if the headplate and heel cap should be glossy. |
Author: | A Peebels [ Mon Oct 08, 2007 12:37 pm ] |
Post subject: | |
Dave I've done it both ways. Al |
Author: | David R White [ Mon Oct 08, 2007 1:08 pm ] |
Post subject: | |
Any preference Al? |
Author: | ballbanjos [ Tue Oct 09, 2007 1:12 am ] |
Post subject: | |
[QUOTE=James W B]Dave,Did you use the Tru-Oil sealer first or just the Tru-Oil.I`ll be using it on my current build for the neck and was curious. James[/QUOTE] I've never used the sealer--I either use it directly on the wood or over shellac. I'm reading mostly about using Tru Oil for a satin finish on this thread, but it will polish to a very lustrous gloss too using the standard polishing compounds. Dave |
Author: | Dave-SKG [ Tue Oct 09, 2007 2:36 am ] |
Post subject: | |
James, I didn't know that Tru Oil made a sealer I just followed Al's instructions. I think the finger rub thing is great. You really get to "feel" the finish and when your done just wipe your fingers off on a paper towel. The clean up is so easy. I'm a fan for sure. |
Author: | davidmor [ Wed Oct 10, 2007 7:03 am ] |
Post subject: | |
I have a quick question.... is the tru-oil that LMI sells the same stuff as the tru-oil gun stock finish that Woodcraft sells? I want to try it on the two I am in the process of building and Woodcraft has it locally in 8 oz bottles at less than half the per oz cost that LMI has it. |
Author: | jhowell [ Wed Oct 10, 2007 8:17 am ] |
Post subject: | |
Birchwood-Casey makes the stuff. The best prices I have found have been at gun shops, er, sporting goods stores. Its all the same as far as I know. |
Author: | Steve Walden [ Wed Oct 10, 2007 8:59 am ] |
Post subject: | |
Here is Birchwood's website: http://www.birchwoodcasey.com/sport/wood_index.asp?categoryI D=5&subcat=11&prodcat=&add=23035#80 |
