Neck reset challenge http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=13900 |
Author: | sbrunker [ Fri Oct 05, 2007 2:11 am ] |
Post subject: | |
Author: | Michael Dale Payne [ Fri Oct 05, 2007 2:47 am ] |
Post subject: | |
I would almost be tempted to take off the peghead veneer and fretboard if possible and build a new butt joint bolted neck for it. |
Author: | sbrunker [ Fri Oct 05, 2007 3:05 am ] |
Post subject: | |
Neat idea |
Author: | FishtownMike [ Fri Oct 05, 2007 6:57 am ] |
Post subject: | |
You could probably easily steam out the piece still in the dovetail and rejoin it to the neck with with the use of dows and glue. It seems like the strap button might have been the culprit. Maybe the maker didnt drill a proper whole wide or deep enough. Putting some stress in that area. I'm sure a good repairman in your area could do a nice job with that. |
Author: | Michael Dale Payne [ Fri Oct 05, 2007 7:20 am ] |
Post subject: | |
I would look at separating it from the neck with heat and a seam knife if possible, if not the band saw it off the thickness sand it down to just the veneer. The neck is repairable The issue I am afraid of is the adding an adjustable truss rod. If I am looking at the picture correctly the steel bar that is in there is not adjustable and is only reinforcement. Correct? If this is the case it would likely be easier to fabricate a butt joint bolt on neck with rod access at the peghead than to try to modify that neck for an adjustable truss rod. If it were not for that I would say the repair the neck. |
Author: | sbrunker [ Fri Oct 05, 2007 7:30 am ] |
Post subject: | |
Author: | sbrunker [ Fri Oct 05, 2007 7:36 am ] |
Post subject: | |
[QUOTE=MichaelP]If I am looking at the picture correctly the steel bar that is in there is not adjustable and is only reinforcement. Correct? Yep, that's right. There isn't a truss rod. I'm not sure what that is protruding from the neck onto the fretboard extension, but you're probably correct there as well. |
Author: | Michael Dale Payne [ Fri Oct 05, 2007 8:07 am ] |
Post subject: | |
Not counting changing to an adjustable truss rod. This would have bee an easy repair if the neck had not been glued bac togather. If the Dovetail was steamed out before the glue up then it would have been a typicl neck set repair plus abreak repair. Glueing back up was not the best idea. |
Author: | sbrunker [ Fri Oct 05, 2007 8:55 am ] |
Post subject: | |
Author: | TonyKarol [ Sat Oct 06, 2007 1:10 am ] |
Post subject: | |
Having done t before, and providing the same adice to AZ, the best way IMO to ge the headstock face off is to cut the headstock off, then resaw the rear off the headstock remaining, then thickness sand whats left till you get jsut the faceplate and binding. You might want to leave it a hiar thick as I woudlnt count on the binding and shell remaining intact if it gets thin. Same thing if you want to save the FB - cut the back of the neck off, close to the truss rod, then plane/chisel/sand until you can pull the truss rod out, then remove whatever wood is remaining on the back of the FB. I would then make a new neck, bolt on heel, fill the dovetail cavity flush, drill bolt holes and then coutersink with a bit like Frank Ford has (I made a similar one from a spade bit - just grind the flange area sharp and it will cut in reverse on the pull). Its a lot of work but not impossible - count on it being at least 1K - I wouldnt do it for any less ... |
Author: | John Lewis [ Sat Oct 06, 2007 12:17 pm ] |
Post subject: | |
Hi Stuart- Try to track down Tony Noble in/around the Austin area. He used to work as a repairman at Erlewine guitars in Austin before venturing out on his own as a custom builder and repairman. I think he also used to write an article for Vintage Guitar magazine. He did work for me on a few guitars a good while back and it was first rate work. Good luck- |
Author: | John Lewis [ Sat Oct 06, 2007 12:28 pm ] |
Post subject: | |
Oops- That's Tony Nobles and I just checked out the Vintage Guitar magazine website - he is at Precision Guitarworks where he builds custom guitars and does repairs and guitar refins. Precision Guitarworks, Ltd. 14 Brookside Drive, Wimberley, TX 78676-2602 (512) 847-3700 I hope this info is current. |
Author: | sbrunker [ Sat Oct 06, 2007 3:12 pm ] |
Post subject: | |
And thank you, Tony, for the thoughts. I really enjoy using things like this as a learning opportunity. |
Author: | Rick Turner [ Sat Oct 06, 2007 4:10 pm ] |
Post subject: | |
Do I detect a pushing in of the neck and neck block into the top? Or was the guitar made with the sided going in slightly concave at the neck attachment. And was that really a huge amount of wood filler there between the body and the face of the side of the heel? Holy crap! That sucker needs a new neck at the very least. Save the peghead and fingerboard if you love them and have a decently fitted neck put on whether it be dovetailed (I wouldn't) or bolted (I would). This is a perfect example of designing a guitar from the outside in and paying more attention to bling than performance. |
Author: | sbrunker [ Sat Oct 06, 2007 4:35 pm ] |
Post subject: | |
Keen observation. Thanks for taking a look. I had hoped to get your two cents on this guitar. These pictures are as close as I've ever been to the guitar, so I don't know if it's wood filler, but it certainly could be. |
