Spanish cedar for steel string necks? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=13862 |
Author: | burbank [ Tue Oct 02, 2007 3:09 pm ] |
Post subject: | |
Anybody had issues with a Spanish cedar neck on a steel string? |
Author: | davidmor [ Wed Oct 03, 2007 12:11 am ] |
Post subject: | |
[QUOTE=burbank]Anybody had issues with a Spanish cedar neck on a steel string?[/QUOTE] I used spanish cedar on this one. So far, so good...... ![]() ![]() |
Author: | Robbie O'Brien [ Wed Oct 03, 2007 1:39 am ] |
Post subject: | |
I recently heard that Martin has been using cedro for a couple of years. Anybody know for sure? |
Author: | Marc Lupien [ Wed Oct 03, 2007 3:04 am ] |
Post subject: | |
I have built a tavel guitar using a spanish cedar neck in 1998. For the first couple of years I could not play it in winter since a backbow was present in the drier season. It appears ok now... I would do it again, but would use a double-action truss rod. In fact, since this guitar, I stopped making my own rods and buy hot rods. Hope this helps... Marc |
Author: | DP LaPlante [ Thu Oct 04, 2007 5:52 am ] |
Post subject: | |
Indeed Robbie, Martin has been using cedar for quite a while now and it continues to cause dyed-in-the-wool Martin fans no small amount of consternation. Not because of any deficiency in the material, I love the stuff......but because now rather than "genuine Mahogany" in the model descriptions it now reads "selected hardwoods". Most of these folks aren't aware that Martin used Spanish cedar for necks all during the 19th and early twentieth century. I've worked with Martin necks in both woods and considering their truss rodded construction , I think the flap is unwarranted. |
Author: | burbank [ Thu Oct 04, 2007 10:54 am ] |
Post subject: | |
If I recall correctly, the lower and middle-priced Martins got the Spanish cedar necks first, then as time went on, the change crept gradually up into the higher priced ones. I thought Martin might have gone to mahogany around the time they switched to steel strings, as I'd heard that the Spanish cedar was less stiff than mahogany, but it appears that might not be true, or at least not an issue. Thanks for the info! |
Author: | burbank [ Thu Oct 04, 2007 10:55 am ] |
Post subject: | |
...and David, that's a real beauty! |
Author: | Rick Turner [ Thu Oct 04, 2007 2:36 pm ] |
Post subject: | |
The down sides to cedro are that it is a bit less stiff than mahogany and it doesn't work quite as nicely. The up sides are that it is very light weight, it smells wonderful, and it looks nice. And it's true that real "vintage" Martins had cedro necks. Just throw some graphite in there with a double acting truss rod, and it's just fine...and very traditional. |
Author: | Dave White [ Thu Oct 04, 2007 5:25 pm ] |
Post subject: | |
[QUOTE=Rick Turner] The up sides are that it is very light weight, it smells wonderful, and it looks nice. [/QUOTE] Just don't lick it ![]() |
Author: | Robbie O'Brien [ Fri Oct 05, 2007 2:46 am ] |
Post subject: | |
I have been using Cedro Rosa, the Brazilian version of Spanish cedar for years and love the stuff. I use it for necks on my classical guitars and some steel string guitars as well as for all back braces, side braces and even kerfing. In my opinion it is easier to carve than mahogany. Makes your guitars smell real nice too. |
Author: | davidmor [ Fri Oct 05, 2007 3:41 am ] |
Post subject: | |
[QUOTE=Dave White] [QUOTE=Rick Turner] The up sides are that it is very light weight, it smells wonderful, and it looks nice. [/QUOTE] Just don't lick it ![]() ![]() ![]() |
Author: | Darin Spayd [ Sat Oct 06, 2007 7:58 am ] |
Post subject: | |
I'll tell you this much. The smell of the cedar lining in my low-end Martin was the "venom" that infected me once "bitten"! And the obsession continues!!! ![]() |
