ROS Techniques? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=13826 |
Author: | sbrunker [ Sat Sep 29, 2007 3:56 am ] |
Post subject: | |
I finished rebinding my guitar and have it ready for Z-Poxy fill. I was using my newly purchased 12,000 RPM Hitachi 5" ROS to sand the epoxy off of scrap and left a couple of deep indentions where I didn't meet the surface dead on. That experience has me thinking a sanding block won't be such a bad idea until I figure this little badger out. What's the worst thing you ever did to a guitar with a ROS? What do you do now, other than being extra carefull, to compensate? Redoing the bindings was painful enough for me to consider asking here before I jump right in, hence the question. |
Author: | JohnAbercrombie [ Sat Sep 29, 2007 4:27 am ] |
Post subject: | |
Stuart- You'll figure out the ROS with a bit more experience. For anything critical, a sanding block is probably a safer alternative- at least mistakes take longer to develop. With a ROS, less pressure is better. Also, resist the temptation to use the edge of the disk if you are trying to get a level surface. Keep the paper clean- if there is even a small 'lump' stuck to the paper , your work will be covered in small circular scratches. A dust vacuum on the sander can help a lot with this. If you want a really level surface (like guitar sides), a firm sanding block is the route to go, for most of us. Cheers John |
Author: | sbrunker [ Sat Sep 29, 2007 4:38 am ] |
Post subject: | |
Thanks, John. |
Author: | sbrunker [ Sat Sep 29, 2007 5:02 am ] |
Post subject: | |
Think this thing's going back then. I liked the way it fit in my hand and since it was roughly the same price as the Bosch and DeWalt models setting next to it, I assumed it was a "good" tool. :-( Is variable speed a necessity? The only VS I've seen is a PC, at an extra $20. |
Author: | sbrunker [ Sat Sep 29, 2007 5:40 am ] |
Post subject: | |
Thanks, Todd. |
Author: | James Orr [ Sat Sep 29, 2007 8:18 am ] |
Post subject: | |
I'm a new Festool ETS 125 owner and really like it. No airborn dust, even without the vacuum they sell, and the papers are great. The salesman recommended it over the dynabride when I asked. |
Author: | Allen McFarlen [ Sat Sep 29, 2007 8:27 am ] |
Post subject: | |
The tool of choice in all the Panel Beater Shops I've worked in for fine sanding is the Festool line. They're a big ticket item but nothing beats them for quality of finish and durability. And believe me, sanders get abused in this line of work. |
Author: | sbrunker [ Sat Sep 29, 2007 8:37 am ] |
Post subject: | |
I take it the little dust collection bags aren't good enough and these things idealy should be connected to a shop vac, et al? |
Author: | WaddyThomson [ Sat Sep 29, 2007 2:21 pm ] |
Post subject: | |
My PC, when you take off the plastic dust catcher, is designed to accept a small 1" or a standard 1 1/2' hose. I hook it directly to my "Shop Vac" and get no airborne dust. No adapter required. |
Author: | sbrunker [ Sat Sep 29, 2007 2:42 pm ] |
Post subject: | |
