Veneer http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=13626 |
Author: | Ziegenfuss [ Thu Sep 13, 2007 8:07 am ] |
Post subject: | |
Does anyone know of any nice, generally available material that could be used as a laminate between wood layers in solid bodies? I need a black veneer about the thickness of poster board. LMII sells the fiber veneer, but it is quite expensive...RCTonewoods is much more reasonable, and I am about to get some stuff from him, but I wanted to see what others have done first...
Thanks Stephen |
Author: | KenH [ Thu Sep 13, 2007 12:50 pm ] |
Post subject: | |
I bought black dyed veneer, but it is .027 thick. I use it sometimes on rosettes and what have you. I also bought some maple veneer that I use the same way, making a BWB strip for various things. I also purchased some of the black and white fiber from Uncle Bob at RCTonewoods. You wont be unhappy with anything you get from Bob. It's all top notch stuff! |
Author: | LanceK [ Thu Sep 13, 2007 1:17 pm ] |
Post subject: | |
Steve I have some of Bobs black and white fiber, you can check it out tomorrow. |
Author: | Rick Hubka [ Thu Sep 13, 2007 1:58 pm ] |
Post subject: | |
I have purchsed Veneer and Super-Soft 2 here Rick Hubka
Author: | Ziegenfuss [ Thu Sep 13, 2007 11:05 pm ] |
Post subject: | |
Thanks so much for the suggestions...
Author: | A Peebels [ Fri Sep 14, 2007 12:14 am ] |
Post subject: | |
How about carbon fiber cloth and West Systems epoxy? I've used both the cloth, and the mat between laminations and it makes a nice accent line as well as adding stiffness. Al |
Author: | Ziegenfuss [ Fri Sep 14, 2007 1:03 am ] |
Post subject: | |
Yeah, I build and design boats for work, so I have tossed this around quite a bit...I haven't brought myself to the point where I can add composites to wood - but that is only because of me....I have no idea of its affect on the dynamics of the body.. |
Author: | Barry Daniels [ Fri Sep 14, 2007 1:14 am ] |
Post subject: | |
I wouldn't add epoxy graphite unless there was a structural reason to do so. An exposed laminate of this material is a lot harder than the surrounding wood which makes shaping and sanding much more difficult. It is difficult not to end up with a slightly protruding surface where the material is exposed. |
Author: | Rick Hubka [ Fri Sep 14, 2007 3:20 am ] |
Post subject: | |
[QUOTE=BarryDaniels]exposed laminate of this material is a lot harder than the surrounding wood[/QUOTE] Yup... One of my favorite Japanese saws now has many broken teeth from trying to cut cured bi-directional carbon fiber. Depending on the epoxy used, CF cuts beautiful with a utility knife blade when it is about 60-70% cured. But when 100% curred the bi-directional stuff I had cut like steel. |
