It is currently Sun Sep 21, 2025 7:18 am
PostPosted: Wed Sep 19, 2007 11:55 am
First name: Jim
Last Name: Kirby
What blade stiffeners do you prefer to use with Shane's fret saw blades?
I was using the blade with the 3" stiffeners from Woodcraft, and was ripping a binding strip off a back plate (bad move probably, but the blade was in the saw already.) The 3" stiffeners were not enough to keep the blade from warping or wandering. I haven't used it yet to saw frets, but want to do a batch of 4 boards soon, so I'm wondering what's optimal?
Jim
Jim Kirby
kirby@udel.edu
PostPosted: Wed Sep 19, 2007 12:03 pm
Lee Valley stiffeners for me.
PostPosted: Wed Sep 19, 2007 12:16 pm
I use the 3" woodcraft stiffeners also. This blade is just too thin to do anything except cut fret slots. The heat generated by cutting anything else will definitely warp the blade.
PostPosted: Wed Sep 19, 2007 12:37 pm
First name: Jim
Last Name: Kirby
[QUOTE=JJ Donohue] Lee Valley stiffeners for me.
3-1/2" or 5" ??
Jim Kirby
kirby@udel.edu
PostPosted: Wed Sep 19, 2007 12:41 pm
5" Lee Valley here.
I only use the blade for it's intended purpose, to cut FB slots. Anything else I use the 7-1/4" diablo
PostPosted: Wed Sep 19, 2007 12:42 pm
5" for me. I tried 3" ones but they weren't much better than using nothing at all. The 5" stiffeners made a world of difference.
PostPosted: Wed Sep 19, 2007 12:49 pm
First name: Jim
Last Name: Kirby
5" it is. Thanks guys!
Jim
Jim Kirby
kirby@udel.edu
PostPosted: Wed Sep 19, 2007 12:59 pm
So Jim, how warped is the blade? You may be cutting to wide of a slot even if it's only warped by a couple of thousanth's    That would suck. If you don't mind my suggesting, test it first, it may be no good for fb slots anymore.
PostPosted: Wed Sep 19, 2007 1:19 pm
First name: Jim
Last Name: Kirby
[QUOTE=Rod True] So Jim, how warped is the blade? You may be cutting to wide of a slot even if it's only warped by a couple of thousanth's    That would suck. If you don't mind my suggesting, test it first, it may be no good for fb slots anymore.[/QUOTE]
I will do that - I think it lies pretty flat on a surface.
I'd hate to have messed it up. I've only been doing ebony boards, and the S-M .023 has been way too narrow as far as I'm concerned, so I really wanted to use the .0245 of Shane's, which I gather is going to drop to .024 on his next batch.
Jim Kirby
kirby@udel.edu
PostPosted: Wed Sep 19, 2007 5:39 pm
Jim (and Ken!),
You need the 5 inch stabilizers. The blades really need that much support. You can get them almost at every woodworking store but most, including me, get them from Lee Valley.
I am hoping that the new blades will be ever so slightly smaller but barely noticeable. If they are too tight then the next order will go back up to .0245 but I really think they will be perfect!
Good luck
