OLF Access speed
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=1358
Author:  dberkowitz [ Wed Mar 16, 2005 12:23 pm ]
Lance, why is the forum access so slow? I've got a DSL line and navigating through the forum has been like swimming thorough corn syrup. What gives? --db
Author:  EricKeller [ Wed Mar 16, 2005 12:36 pm ]
one thing I do is I don't use the back button. I use Firefox, which has tabs. So I go through the forum and open each discussion I am interested to in a new tab. When I am done reading in a thread, I close the tab. When I post, I get a catastrophic failure, and close the tab (I know I didn't have to mention that part)
Navagating the old way is rather slow here, but using tabs makes things fast enough, and you don't get spyware.
Author:  John Mayes [ Wed Mar 16, 2005 12:38 pm ]
[QUOTE=EricKeller] one thing I do is I don't use the back button. I use
fast enough, and you don't get spyware.[/QUOTE]
I use safari and use the tabs... only way I could do it on this server......
Author:  PaulB [ Wed Mar 16, 2005 1:10 pm ]
If you don't want to change browsers, you can always right click on a link and select "open in new window", that's what I used to do before they invented tabbed browsing, speeds things up but you can end up with a lot of windows open.
Mmm, tabbed browsing. You'll never go back.
Author:  LanceK [ Wed Mar 16, 2005 1:12 pm ]
Hang in there guys!-
I swear well be on that new server soon
Author:  Dickey [ Wed Mar 16, 2005 3:00 pm ]
All it needs is a good dose of EXLAX. That'll fix 'er right up.
Author:  John Elshaw [ Wed Mar 16, 2005 3:05 pm ]
For those of you who have Robbie Obrien's CD, go get one of those two cans and open it up all over your computer!
Author:  LanceK [ Wed Mar 16, 2005 11:39 pm ]
you can always use the "Active Topic" Button at the top, it will reduce the load time as all it brings up are the most active topics .
Author:  rlabbe [ Thu Mar 17, 2005 12:54 am ]
[QUOTE=PaulB] If you don't want to change browsers, you can always right click on a link and select "open in new window", that's what I used to do before they invented tabbed browsing, speeds things up but you can end up with a lot of windows open.[/QUOTE] Or just hold down the shift key when you click a link - it does the same thing, but is faster.
Author:  Don A [ Thu Mar 17, 2005 8:34 am ]
[QUOTE=LanceK] you can always use the "Active Topic" Button at the top, it will reduce the load time as all it brings up are the most active topics .[/QUOTE]
I'm with you Lance. Active Topic is one of the highlights of the new software. For some reason, and it may be related to size of database the software has to open (Main vs Active), but I've not been having any speed issues.
