Neck bolts http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=13030 |
Author: | jonhfry [ Tue Jul 31, 2007 2:18 am ] |
Post subject: | |
For those of you that use the bolt on method for your necks, where do buy the bolt with the threads? I know LMI and the usual places have them, but 9 and 12 bucks plus shipping seems a bit high. I just don't want to pay so much if there is a cheaper route. I want to buy a few sets at once. |
Author: | Michael Dale Payne [ Tue Jul 31, 2007 2:35 am ] |
Post subject: | |
Your local Ace Hardware will have the bolts and inserts the hard item to find is Belleville washer. ( dished for spring like resistance) not absolutely necessary but do help to maintain tension on the bolt |
Author: | jonhfry [ Tue Jul 31, 2007 2:55 am ] |
Post subject: | |
I will have to try ACE, I went to home depot and could not find the inserts, Thanks Mike, you are quick |
Author: | Chris Oliver [ Tue Jul 31, 2007 2:58 am ] |
Post subject: | |
John, I you have a Lowe's nearby, there is a section of the fastners section where they have specialty hardware in drawer boxes. You can find them there as well. chris |
Author: | WaddyThomson [ Tue Jul 31, 2007 3:04 am ] |
Post subject: | |
I would not recommend Home Depot for any type of normal screws, bolts, carriage bolts, nuts, etc. Their stuff is sub-standard. I now go to a legitimate commercial supplier type hardware store for all that stuff. The price is not that much different, and when you buy a screw that can be screwed in and removed without buggering up, you have come out ahead anyway. HD screw heads will strip out with a brand new screwdriver tip that fits perfectly, and carriage bolt shafts are 1/16 smaller than the threaded tip. Seems like it would be harder to make them that way. |
Author: | Steve Saville [ Tue Jul 31, 2007 3:57 am ] |
Post subject: | |
Buy online from McMaster Carr or McFeely's. |
Author: | jonhfry [ Tue Jul 31, 2007 6:55 am ] |
Post subject: | |
thanks ya'll |
Author: | Blain [ Tue Jul 31, 2007 4:14 pm ] |
Post subject: | |
McMaster Carr sells the Belleville washer. |
Author: | Colby Horton [ Wed Aug 01, 2007 12:24 am ] |
Post subject: | |
Grizzly also has a pair of bolts, washers, and inserts for the guitar neck joint for around $3.00. I don't use these type of bolts on my neck joints though. |
