Grain Fillers http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10102&t=11616 |
Author: | John Forbus [ Thu Apr 12, 2007 4:47 pm ] |
Post subject: | |
The only grain filler I've tried is the water based from stewmac. That prompted me to go back to spraying sanding more lacquer to level. Is there a grain filler some one is using that works well without a lot of mixing or prep. The stewmac stuff didn't seem to do much at all. |
Author: | Barry Daniels [ Fri Apr 13, 2007 2:15 am ] |
Post subject: | |
I like traditional paste wood pore filler (either water-based or oil-based) mixed with stains to add some color to the wood. Behlen's Pore-o-Pac is a good brand. |
Author: | Alain Desforges [ Fri Apr 13, 2007 2:18 am ] |
Post subject: | |
I'll second the use of epoxies. I use System Three but from what I hear Z-Poxy is just as good if not better and it's cheaper too. Z-Poxy is also more forgiving in mixing ratios than System III. Just be sure to let it cure completely before sanding, at least a good 24 hours. Even more if you can wait that long. A hot and dry environment to cure will help as well. |
