It is currently Thu Feb 20, 2025 2:58 am
PostPosted: Thu Sep 06, 2007 3:04 pm
Hey Everybody,
When resawing some old growth and hand split billets of Western Red
Cedar, I thought I would try the beveling method for detecting runout. I
never put much thought into the method but after a little thinking, I
realized that this method does NOT detect runout and should not be used
for verification. There is a small picture of the method below for those
who haven't heard about it.
The only thing this method does for quartersawn wood with distinct
annular growth lines is show the lengthwise movement of the grain. By
that, I mean if the grain lines are perfectly straight and stay parallel to the
bevel, you will see the lines run straight along the bevel. But if the grain
lines move to the right or left they will appear to move up or down on the
bevel face. Supposedly, this is how you detect runout. But the direction
and movement of the grain lines on the bevel face is entirely unrelated to
runout.
If you disagree, please test this yourself. It only takes a few minutes to
verify and if you stop and ponder it, I think it is fairly obvious. After all
the growth lines are like "sheets" of wood not "strands" of wood. This
means that regardless of how much runout is in the piece, a beveled edge
will show perfectly straight grain as long as the grain runs parallel to the
bevel.
The only methods I know to detect runout are
1) visually on bookmatched sets
2) via touch which doesn't seem to be very reliable
3) the best and only real method is to split a piece of the billet or set and
see how the grain breaks.
This just goes to show that the "tonewood lumberjack" is the really
important part - it is up to them to cut the wood so that any runout is
minimalized.
[IMG]../forum/useruploads/SimonF/2007-09-07_000402_Runout.jpg[/
IMG]
PostPosted: Thu Sep 06, 2007 3:05 pm
I don't know why the picture didn't load. Here it is again.
PostPosted: Thu Sep 06, 2007 3:14 pm
One last thing I wanted to mention. When I was messing around with this
method today, it initially makes a lot of sense. But when you think about
it more, it starts to break down and you realized that it really doesn't.
I remember seeing this photo of a top with extreme runout. If you took
this board and planed the edge, the runout would no longer be visible.
All you would see would be the growth lines running fairly straight down
the board. So an easy way to test this piece for runout would be to cut
off a 1" section at the edge (or however much you could spare) and try
and split the grain with a fine chisel. You would then easily see the
runout and it would once again look very similar to the picture.
So once again, the bevel method doesn't work. Just thought I would
mention this because I never thought to question it and have been relying
on it for the last year or so.
PostPosted: Thu Sep 06, 2007 3:15 pm
Interesting... that image came from an old Guitarmaker mag, and Craig Carter wrote it.
Thanks for the observation.
PostPosted: Thu Sep 06, 2007 10:13 pm
First name: Josh
Last Name: French
City: Houston
I totally agree that the best way is to split a piece of what you are using.
Instagram: @jfrenchluthier
PostPosted: Fri Sep 07, 2007 4:30 am
There's an easier way to detect runout in a quartersawn piece of wood.
Look at the end grain & note the verticality of the grain lines. If they are perfectly vertical on both ends, the board is most likely free of any substantial amount of runout.
If the lines are nice & vertical on one end & lean one way or the other on the opposite end, you have some degree of runout.
If the lines are off vertical at both ends, it gets a bit more complicated... When you are checking for this, hold the board in both hands hand & flip it end for end only. Don't turn the board... If the lines appear as a "back slash" or a "forward slash" on both ends, you have some runout. If the line angles appear to reverse from end to end, your board is off quarter to some degree, but (if the angle is the same on both ends) the runout is minimal.
Extreme runout, like in the spruce picture above is easy to see. The method I described will detect very minor runout easily.
This is a quick & easy method to use if you are grading tops or digging through a stack of wood to pick out the ones you want to buy.
PostPosted: Fri Sep 07, 2007 4:32 am
Im not getting this. I just cut some braces and I made sure the dark streak of grain ran all the way through the brace, and that the ring lines in the top ran down the middle. Are you saying there could still be runout???
PostPosted: Fri Sep 07, 2007 5:32 am
OK, so I've seen runout quantified by measuring the horizontal distance
(along the grain) that the grain takes to go from one face to the
opposite face; then this distance is normalized to the thickness of the
billet.
i.e. like 18" per 1/8" thickess
means that on a 1/8" thick piece, it takes 18" (along the grain) for
the grain to run from the inner face to the outer face.  Get my
drift?
Using that as a metric, what do you suppose is the worst runout
acceptable for a top?  And if you're even better informed....how
would this metric vary among the different grades of soundboard lumber?
PostPosted: Fri Sep 07, 2007 8:59 am
Blackheart, yes, you could still have runout. Beveling the outer edge of a
top (or bracing, etc...) will not reveal any information on whether the top
has runout. The best way to prove this to yourself is to take a piece of
spruce and give it terrible runout and then bevel the edge. As long as the
grain runs parallel to the bevel, the grain lines will run straight down the
board.
DanielM gave a very good suggestion. However, if you spare some
material, I would just cut off a small piece lengthwise and split the grain.
You should be able to see very clearly whether the piece has runout or
not and there would be no question about its certainty. Of course, runout
can vary throughout a piece as wide as what we use for a guitar top.
Erik, I have no idea where to draw the line when it comes to severe
runout. I do know that some people use the flamed redwood for tops and
that is a case of severe runout. I personally would not feel comfortable
using such a top unless it was a double top or left very thick. Maybe
someone with a bit more experience will chime in here and shed some
light on that issue. However, here is an interesting link you might want to
check out. It shows how runout affects the continuity of a bookmatched
set.
Link
PostPosted: Fri Sep 07, 2007 12:12 pm
Thanks for the link Simon.  I recall seeing that photo before, but
I'd forgotten that the runout metrics were scribbled in the corner like
that (just the inverse of the one I recalled).
So where would you grading guys draw your boundaries in that photo??
PostPosted: Fri Sep 07, 2007 12:24 pm
Each of us will find his / her own limits for acceptable runout limits. Speaking personally, if I can clearly see a colour shift in the rough cut top, I would prefer not to use it.
Runout can negatively affect cross grain stiffness. I will reject a top if it feels too floppy.
That being said, each piece of wood has to be considered on it's own merits... & on how it will be used.
I have seen many fine guitars which display clear evidence of top runout... I have no idea whether they would have sounded better or lasted longer with a "better" grade of top.
If you are going to test for runout by splitting a piece of wood, make sure you set your splitting knife as close to the exact centre as possible. If you are off centre, you can get a false runout indication... especially if the piece being tested is fairly thin.
PostPosted: Fri Sep 07, 2007 12:29 pm
PostPosted: Fri Sep 07, 2007 12:31 pm
Sorry guys... I must have hit the button twice!
PostPosted: Sat Sep 08, 2007 3:17 am
That is what I found in this topic-topic
I couldn't detect runnout that I knew was present(referencing the split face. The bevel method shows little more than how the visable grain runs through the board. Looking at the side of a board, the visual clues reflect visual grain that runs out at the edge(which is appearant from looking at the top face).
Splitting or looking at the bookmatch are the two clues I look to. Since I cut my own tops from split wood, it is not really something I have to question.
Peace,Rich
