It is currently Sat Apr 19, 2025 1:13 pm
PostPosted: Mon Feb 19, 2007 11:42 am
Well, I don't want to count my chickens before they hatch, but after 4 coats with the aeorsol Guitar Lacquer, my back and sides are looking *darn* good (toot-toot!). I know that I'm not out of the woods yet, but after a couple of rough starts, I seem to be able to get a very regular spray pattern, and pretty consistent coverage. I'm actully shooting 3-4 light coats per 'shoot', then letting that dry 3-4 hours, light scuff to get any small fuzzies or trash out (slight block sanding to get the one 'near-run' thick spot out, which worked right out, BTW). The initial egg-shell finish smooths out after a few seconds, and apparently any thick spots can be 'set' by holding them horizontal for a little while.
It seems that keeping the can absolutely vertical is key. That, and keep moving, back and forth, with no stopping or short shots... just continual back and forth beyond the body on either side. I was able to get jsut about all the contents out of can #1 without quality of spray deteriorating (Dan Erlewine suggested stopping with about 1/3 left).
This may have all already been noted before, but it's new to me. Some reinvention of the wheel, I'm sure :)
Anyway, I'm keeping my fingers crossed, and moving ahead. Hope this is helpful to someone out there!
Ken
PostPosted: Wed Feb 21, 2007 1:21 am
Ken,
Thanks for the report. Look forward to seeing some pics.
I'm still trying to figure out what I'm going to do about finish on #2 and was
just reading about this product last night.
I'll be watching with interest to see how it all turns out for you.
Christopher C. Cordle
North Muskegon, MI
PostPosted: Wed Feb 21, 2007 2:20 am
[QUOTE=Hesh1956] To borrow a phrase from Paul - not to toot my own
horn, here is one of the many guitars that I finished with Stew-Mac
aerosol Lacquer.
Once I learned to pore fill and started using epoxy and not water based
fillers my results really improved.
OLF SJ - Honduran Rosewood/
WRC/Koa
Hesh,
To me, I think that looks fantastic! That's a finish I would be happy with.
If you don't mind, I'd like to PM you for details on your procedure for
using the spray-bobs.
North Muskegon, MI
