Rosette router bit source?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=56987
Author:  kyle.medeiros [ Wed Feb 19, 2025 11:51 am ]
Post subject:  Rosette router bit source?
Hi all,
My searches through the forum seem to be failing me—recommendations on a source for router bits for rosette routing? I’m using a dewalt 611 trim router with the precise bits collet (thanks Hesh and others!) in a homemade base (thanks Trevor G for the inspiration!) and now would appreciate a source for the best bits for both narrow purfling lines and slightly larger bits (I assume?) for clearing the main field.
Any other tips are always greatly appreciated as well!
Thanks in advance!
Author:  J De Rocher [ Wed Feb 19, 2025 1:32 pm ]
Post subject:  Re: Rosette router bit source?
I've gotten my bits for rosettes (and inlays) from StewMac and MSC Industrial Supply.
Author:  Terence Kennedy [ Wed Feb 19, 2025 7:25 pm ]
Stew Mac for me. With the volume discount it’s a good deal.
Author:  Michaeldc [ Thu Feb 20, 2025 10:58 am ]
A couple more:
https://www.hvalleytools.com/category/e ... outer-bits
https://www.precisebits.com/products/ca ... /shell.asp
https://www.6gtools.com/milling/end-mills.html
Author:  kyle.medeiros [ Sat Feb 22, 2025 2:56 pm ]
Thanks all—am I correct that the downcut bits are preferred for the rosette? Any reason I’d want to
Use a different bit, especially for thinner purfling lines?
Author:  doncaparker [ Sat Feb 22, 2025 3:13 pm ]
I can't speak for everyone, but I use spiral downcut bits for cutting rosette channels because I want the cutting at the surface level to be as clean as possible, and I'm not all that worried about expelling chips/dust from the channel. That's always the choice with upcut/downcut bits. Upcut clears the chips/dust, but can leave a ragged edge at the surface. Downcut leaves a cleaner surface, but can leave the chips/dust packed into the channel. Downcut is the better choice for me in this instance.
Author:  J De Rocher [ Sat Feb 22, 2025 3:48 pm ]
Downcut for me too.
Author:  meddlingfool [ Sat Feb 22, 2025 4:08 pm ]
Ditto downcut. Think I got mine at Lee Valley…
Author:  oval soundhole [ Sat Feb 22, 2025 4:29 pm ]
I bought about 20 1/16" spiral downcut bits from drill bit city about 15 years ago that are really great; I think
I've only retired 4 after 50 or so guitars. I'm not sure if that company is still around or if their quality is the same but I can recommend the Stew Mac bits fully. I have a few of the Stew Mac bits and although pricy definitely cut cleanly and precisely. Worth the money in my opinion.
