It is currently Fri Jul 18, 2025 4:58 pm
PostPosted: Wed May 15, 2024 10:06 pm
Does anyone use Fish Glue to attach the top to the sides?
It would seem to have the advantages of hot hide glue with a longer open time.
Formerly know as Mandodiddle.
PostPosted: Wed May 15, 2024 10:29 pm
Some people have reported fish glue to be less resistant to high humidity conditions than hot hide glue so I have not used it.
PostPosted: Wed May 15, 2024 10:42 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
titebond/titebond extend. Known and tested. No reason to go into unknown territory.
Peter Havriluk
PostPosted: Thu May 16, 2024 4:26 am
been using it for 20 yr no issue
Wayne uses it
there are issues if you use the wrong stuff. Not all fish glue is the same.
How many here actually used it??? and what did you use?
I use High Tack fish glue. Been using it for braces and attaching top and back.
you need to allow 18 to24 hr clamp time. Be sure your joints mate well
I had one guitar that had some issues after the owner thew a wet rag into the guitar for humidity. And in that case any glue would fail.
NOTE: Fish glue and Hide glue are drying glues. In plain words they must dry out for the glue to be 100% effective. So clamping time is important. Your surfaces must be well mated.
There is no reason not to stay with tight bond as that is a proven glue used in many production shops
Glues to avoid
bottled hide glue
tite bond 2 3 4 just use the original.
also white elmers is a good glue as well
The glue you choose needs to be reversible . Tite bond will separate at about 145F as fish and hide .
These users thanked the author bluescreek for the post: Robbie_McD (Sun May 26, 2024 9:56 am)
PostPosted: Thu May 16, 2024 7:06 am
First name: Ken
Last Name: Nagy
City: Goodrich
I have used it on some things. A guy at a violin shop that I showed an instrument to years ago gave me a small bottle of fish glue. He puts a larger bottle into small bottles, and keeps them in a fridge. I like the stickiness. I does dry slower so you have to clamp it.
I did glue the top on the viola I just finished with HHG just by clamping it. I had a thin size on both ribs and belly. I clamped it all up, and brushed water around the sides to clean the ribs. I put it on the electric baseboard heater to get it good and hot to glue, flipping to get both side hot.
I couldn't pull it apart! Worked amazingly well.
Why be normal?
PostPosted: Thu May 16, 2024 7:53 am
If you use fish glue, use a proven brand, and be sure to MIX WELL before using.
If you are taking glue from a large container and putting it into a smaller container, be sure to mix the glue in the larger container very well, before the transfer. Each time you use the small container, just slowly flip it end over, end 8 or 10 times, to mix it thoroughly. It is a little too thick for shaking, and stirring a small bottle is a pain, because the screw on lid will always be stuck.:>)
PostPosted: Thu May 16, 2024 9:00 am
First name: Ken
Last Name: Nagy
City: Goodrich
That's why I like mixing 1/4, 1/2, or a teaspoon of glue, with 3/4, 1,5 teaspoons, or a tablespoon of water. A teaspoon will last me a long time, or do joins on even an archtop. 3:1 it is a little thin at first, but it doesn't Gell so fast. After heating a few times it is about perfect. Maybe theoretically not as strong; but I mix up fresh most of the time.
I'm doing ribs, and liners, and an extra "binding" on a viola ribcage now. So it is maybe 4 little pieces of wood to glue each day. I don't see them going anywhere. A teaspoon of glue and a tablespoon of water fills up a small plastic medicine cup. I float it on the hot water can, in a cutout to keep it from tipping, with a jar on top.
Does anyone sell fish glue in small containers. Mine from StewMac is in a large tube, and it is probably 4 years old or more. I think that you can by it dehydrated, but I haven't checked into it. The Japanese use it?
Why be normal?
PostPosted: Thu May 16, 2024 10:58 am
In my experience fish glue is a lot tougher than HHG, and hence harder to get apart using the usual methods that work for hide glue, which take advantage of it's brittle nature.
PostPosted: Thu May 16, 2024 12:44 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
I do. Clamp with gobars and a halo. Braces too. Leave overnight or more.
PostPosted: Thu May 16, 2024 1:55 pm
First name: Tim
Last Name: Allen
City: San Francisco
I use it for many things. My experience parallels that of John and Alan.
Tim Allen
"Never hurry, never rest."
PostPosted: Sat May 18, 2024 8:30 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Hot hide's open time is easy to work around when closing the box. Apply 192g to both rim and plate, align in the go-bar deck, load the deck with clamping caul and bars, then warm the joint with a heat gun. Do the back first, let things set for 10-15 minutes, then de-clamp, swap dishes, and get the top on. A good blast of heat gun into the soundhole will keep things from cooling off too much before a final exterior pass or two around the joint. My chosen method before I developed the speed to get things closed and clamped with just some preheating and a warmish shop.
- Beth Brower
These users thanked the author Woodie G for the post: Hesh (Sat May 18, 2024 8:32 am)
PostPosted: Sat May 18, 2024 9:04 am
Seconded Woodie's idea that you can use HHG to close a box. Remember many companies used HHG for everything back in the day they didn't have modern glues.
The most interesting method that I have ever seen to use HHG to close a box was from Mario and he made a video of him doing it and maybe someone can find it it was once posted on the OLF.
Mario exploited the idea of glue viscosity and thicker viscosity in his method which was the fascinating part to me. He pre heated like Woodie suggests and then used thicker viscosity of HHG and laid down a heavy, thick bead on the top side of the rim. He did not apply to the top at all but IIRC he did preheat the top with a heat gun as well as the rim.
Mario relied on the thicker viscosity of his HHG to form a thick, tall bead around the rim that the outer layer would cool first thusly encasing the inner layer of liquid glue and helping to keep it warm a bit longer.
Think Tylenol gelcaps....
Then he places the back, preheated again, on the proud bead/gelcap all around the rim and as he applies the clamps the bead is broken, the liquid, HHG runs out and distributes on all the horizontal surfaces of the linings and sides with excess squeeze out visible and ready to be wiped up. I think he also reheated the rim with the heat gun just where the back met the rim to be sure the liquid HHG did flow everywhere and then he called it a day.
Beautiful! I may have some of his method wrong of course it was over ten years ago and I only saw this video once.
I'd ask him, we are friends on Facebook if he still has the video but he was one of the pros who left the OLF because of the know it alls who don't and I understand how he feels about this and respect him greatly.
But what a great method.
One last thing I think the world of my friend John Hall and I was not going to bring it up but there are many posts here on the OLF of fish glue failures and when this is brought up it often devolves when someone tries to protect what they believe for better or worse.
We used it, bought directly from Norland who was the only maker stateside back 18 years ago when we bought ours and they may be still I'm not up on it. We are in Michigan and have a thing called or used to have a thing called winter. I can't remember the exact numbers but within 6 months, seasonal change we had a bridge lift. We had used Fish glue, handled it exactly as Norland prescribes and even parted it out into sterilized Mason jars so the bulk would stay fresh and we stored it in our fridge.
Then another lifted bridge came back and of course we repaired this at no charge and with HHG. We went though our receipts and proactively contacted a two dozen of so bridge reglue clients and offered them free reglues with HHG. Of the maybe 9 that came back there were lifted back edges on three of them IIRC that had not been noticed yet by the owners.
We pitched or Fish glue and never used it again for anything.
So we are not alone I would estimate 2 dozen posts on the OLF of people who had Fish not hold up when the humidity rises even though it never harmed the fish swimming in the ocean and they did not fall apart... :)
If your instrument may sometime in it's life live where the humidity may be higher I would not recommend Fish glue use at all and especially for bridges. It really set us back and cost us in both opportunity costs and our reputation and we can't have that.
Now that someone came out as not being a fish fan others may relate what fell apart for them.
But back to HHG it's a great solution and it can be fun too to learn how to work with it. We've always fancied a hot room like the violin makers use where it's 125F maybe and you do your gluing in your boxers unless of course you go commando.
Lastly if you build a classical with less tension than a steel string, keep the instrument in a humidity controlled case and never really subject it to the rigors of a traveling, gigging musical Fish may work for you but I still would not recommend it.
I'm sad to have to share this Fish was in all other ways very attractive including how hard it dries and it still is reversible.
I have a bit of a dispute unfortunately happening over one of my tutorials more specifically the nut slots. What is behind the dispute is a very basic idea that I doubt the other parties would even agree is in play here. You do not set-up a guitar for the best case situation with the light hitters you set up a guitar in some cases for Pete Townshend and if you don't know how someone hits you favor the higher side so they don't have to come back unless it's with a second guitar for more set-up.
Likewise do you build for the idea that it will be kept in a humidity controlled case, adult owned, cared for very well and never leave the house? Or do you build for one of my clients who did leave a Heshtone in a hot car in Nashville for a week while he was doing session work and got drunk and put in jail? My bridge did lift by the way and it was glued with HHG. ;)
These users thanked the author Hesh for the post: Kbore (Sat May 18, 2024 11:50 am)
PostPosted: Sat May 18, 2024 9:59 am
First name: Brad
Last Name: Combs
Here you go, Hesh - https://www.youtube.com/watch?v=TC78Z9zFG0I
Judging by the fact that Mario plays a lot of Prine, JTE and even Blaze Foley (love playing Clay Pigeons!), I bet we would have been friends here on the OLF. :D
These users thanked the author bcombs510 for the post (total 2): Kbore (Sat May 18, 2024 11:51 am) • Hesh (Sat May 18, 2024 10:27 am)
PostPosted: Sat May 18, 2024 10:34 am
Brad you are a mensch! :D Thank You and I hope that I don't lean on you too much you have as much it seems memory of what's this forum as I do!
You would like Mario and he would like and respect you too. Back when the forum had a different crew that seemed to leave more of our egos, not always but much of the time at home in favor of letting the folks who walk the walk walk the walk here Mario was perhaps the one nearly everyone listened to more than anyone else. He had a five year waiting list for his superb guitars.
I fought with him too like cats and dogs but when I got to meet him and he came to Ann Arbor to our gathering that attracted nearly 50 OLFers we both lightened up and found something to like about the other one. I freely admit that our disagreements were nearly if not all my fault so I have been on both sides of the dispute as to why the OLF can't retain highly contributing pro Luthiers. My fighting with Mario harmed everyone on the forum, sadly I had to learn that.
Anyway thanks man if your weather is like mine we have the best day of the year happening out there!
These users thanked the author Hesh for the post (total 2): Kbore (Sat May 18, 2024 11:52 am) • bcombs510 (Sat May 18, 2024 10:46 am)
PostPosted: Sun May 19, 2024 8:33 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
OK, I will admit it, I am with John here, lots of fish glue used in my shop - we live in a very dry climate here, no humidity issues. The long open is such a bonus. 60 guitars in.. However I did see 2 bridge lifting issues in the past :-(
Have used HHG for bridges ever since, using the Hesh method....
These users thanked the author Robbie_McD for the post: Hesh (Mon May 20, 2024 3:59 am)
PostPosted: Wed May 22, 2024 7:38 pm
First name: George
City: Seattle
Yes, I have used fish glue to attach the top plate to the ribs on several guitars, one of which was made for my daughter around 13 years ago. She’s been living in Costa Rica for the last three years. I’m actually visiting her now. The current RH is ~89% and she uses no humidity control. (Always was a free spirit!) I played the guitar today and it’s holding up fine.
George :-)
PostPosted: Wed May 22, 2024 8:40 pm
I use mostly HHG, because it's fun to work with (not everybody thinks so). I also use Lee Valley 2002 cabinet makers glue, and a glue from a piano manufacturer called "Acoustic Glue". The last two have similar characteristics to HHG. They have good initial grab, and stay on the surface (instead of soaking in), dry 'glass hard' and are reversible with heat. So I haven't needed to try anything new.
Brent
These users thanked the author bftobin for the post: bcombs510 (Wed May 22, 2024 9:21 pm)
PostPosted: Wed May 22, 2024 9:22 pm
First name: Brad
Last Name: Combs
The fish glue I’ve used is the Lee Valley high tack. The only issue I had with it when I used it for lining was I couldn’t get rid of the shiny bead of glue in the corners. I tried, it wasn’t happening. :) Just a minor annoyance.
PostPosted: Thu May 23, 2024 12:07 am
Online
What is this piano makers acoustic glue?
PostPosted: Thu May 23, 2024 11:11 am
I can't remember the name just offhand, but they are in Quebec. It's a low water glue that grabs pretty quick compared to TB, and dries to a semi-transparent white color. It's a lot like Lee Valley's cabinetmakers glue. The high solids content helps especially if your surfaces aren't perfect. I'll let you know if I come up the name.
Brent
These users thanked the author bftobin for the post: meddlingfool (Thu May 23, 2024 12:28 pm)
PostPosted: Tue May 28, 2024 6:23 am
Brent
Could it be this https://shop.pianosbolduc.com/products/bolduc-s-acoustic-wood-glue
These users thanked the author Colin North for the post: bcombs510 (Tue May 28, 2024 7:52 am)
PostPosted: Tue May 28, 2024 10:14 am
Colin North wrote:
Brent
Yup. That's the one.
These users thanked the author bftobin for the post: bcombs510 (Tue May 28, 2024 10:28 am)
PostPosted: Tue May 28, 2024 10:23 am
Some Spanish builders (in the old days) had a unique way of doing things. To glue the back on, they would notch the back braces into the linings and put HHG on the braces. Then they would position and clamp the back in place. Once everything was aligned, they would pour alcohol on the back and light it up. The heat would melt the HHG and hold the back on when it cooled.
Users browsing this forum: meddlingfool and 18 guests
