Sloppy rosette fit fix
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=56447
Page 1 of 2
Author:  Duct Tape [ Sun Mar 03, 2024 9:26 pm ]
Post subject:  Sloppy rosette fit fix
On one of my three OOO-12 cutaways I’m building my segmented rosette turned out to not be a perfect circle. Once I inlayed it into the channel in the spruce SB top, there is a small gap in two areas. The rosette is a combination of ebony and rosewood pieces so fairly dark. Could I use Ebony sawdust to fill the gaps, maybe with CA glue? I’m concerned about stains in the spruce wood, although I did add a single shellac wash coat. Appreciate any advice. Thanks much.
Author:  bcombs510 [ Sun Mar 03, 2024 9:28 pm ]
Post subject:  Re: Sloppy rosette fit fix
Any pics?
I would think brushing some more shellac into the gap areas couldn’t hurt before you start the fix. If it’s significant, consider inlaying some rosewood for most of the gap and fill around that with dust vs the entire gap.
Author:  Darrel Friesen [ Sun Mar 03, 2024 9:36 pm ]
Like Brad says. Pics would help. Epoxy and ebony or rosewood dust shouldn't wick like CA may.
Author:  Duct Tape [ Sun Mar 03, 2024 9:44 pm ]
It’s in the Go Bar deck right now, with Tightbond as the glue. I’m out tomorrow but might be able to get some,pics after I get back. Thx
Author:  meddlingfool [ Sun Mar 03, 2024 9:46 pm ]
Have you cut out the sound hole yet? ‘Cause of you can get it back on your rosette cutter you could add a line of purfling…
Author:  Duct Tape [ Sun Mar 03, 2024 9:51 pm ]
That was my back up plan. Would need to cut into rosette on both inside and outside some to clean up the circle and add room for purfling. Sound hole not cut yet. But don’t want it to get too busy.
Author:  meddlingfool [ Sun Mar 03, 2024 10:14 pm ]
Likely a well cut consistent extra line of purfling will look better than a dust filled section in one spot…
Author:  Hesh [ Mon Mar 04, 2024 4:39 am ]
Sloppy inlay work :) Duct Tape consider doing what G*bson has done for decades with their logo use copious amounts of black filler and call it good, good enough for a G*bson ;)
Author:  SteveSmith [ Mon Mar 04, 2024 6:57 am ]
Just use black purfling and it shouldn’t look any busier.
Author:  Clay S. [ Mon Mar 04, 2024 11:15 am ]
Back when I was building furniture we would make filler for small gaps using fine sawdust and the finish material the piece was finished with as a "binder". . This seemed to give the best match for color and could make small gaps "disappear", better than Titebond or CA that some people use.
Author:  wbergman [ Mon Mar 04, 2024 2:15 pm ]
When I am dusting in a gap, I use diluted Elmers school glue. The glue dries transparent and colorless. Gap filling should not require any strength.
Author:  Duct Tape [ Tue Mar 05, 2024 7:04 pm ]
bcombs510 wrote:
Any pics?
I’ve tried to post pics but can’t. In the FAQ it says they need to be on a public server, not on just my iPad. Also searched “how to” but no luck.
Anyway, adding a piece of purfling both inside and out worked great. Also finished my other two guitar tops. All three have rosettes installed and are thicknessed, and ready for bracing. Thanks for advice here.
Jon
Author:  meddlingfool [ Tue Mar 05, 2024 7:07 pm ]
Glad it worked out! I use TapaTalk for posting pics, works as easy as facebook and you can post from your iPad…
Author:  Dave m2 [ Wed Mar 06, 2024 12:08 pm ]
Jon posting pics from your device, tablet - PC etc is perfectly doable. Preferable really since hosting services sometimes disappear.
The usual problem is size. Your file has be less than a certain size - can't remember exactly but I seem to remember about 270 K.
However if this is the problem the software will tell as you try to load the file.
I use Photoshop Elements (just because I have it) to both reduce the image size then save it as a lower resolution, and hence smaller file. But there is plenty of other software that will do the trick
Hope it helps. I'm sure the info is on the forum but I can never find it!
Cheers Dave
Author:  Ken Nagy [ Wed Mar 06, 2024 12:40 pm ]
I think the size is 256k. I do photos from iMac. View the photo in preview. Go to tools, then adjust size. I just change the size from whatever resolution is there to whatever gives me something under 256. I don't have an iPad, but I would think it would be similar.
Author:  Duct Tape [ Thu Mar 07, 2024 11:31 am ]
Ken and Dave,
Do you mind telling me how to post from your Mac or iPad? When I start a new post or full reply there are multiple little icons along the top, including .img, etc. But none of them seem to work as I’m used to in several other forums.
And in this Quick Reply none of those icons are there.
I did research this in the FAQ and under several searches but only found the web hosting options. I don’t have Tapatalk.
Thanks, Jon. Over 65 but still not yet completely tech challenged! :)
Author:  Dave m2 [ Thu Mar 07, 2024 12:14 pm ]
There is a section at the bottom of the post or reply page where you can attach a file. This is easy on the PC - I can't comment on the Apple devices. Dave
Author:  Mark Mc [ Thu Mar 07, 2024 7:03 pm ]
I am posting this from an iPad.
Hit the “full editor” button
Scroll down to the section headed “upload attachment” and click on the highlighted text “choose file”
This will open a box that allows you to choose a saved file, or a photo from your library, or to take a new photo. Choose the file you want and press done. You can also add a caption in the dialog box below that. It will try to upload the photo file into your message. You see a text line inserted in the message composer (not the actual image) but you will see the image if you try preview, or if you submit.
The common problem is that it fails to load the image because the file is too big. I just tried to load a random photo into this post and got an error message “The file is too big, maximum allowable size is 256 kB”. Most photos taken on your iPad are over 1.2 mB. You need to use a resizing app to reduce the size of the photo. There are lots of free ones available.
Author:  Darrel Friesen [ Thu Mar 07, 2024 7:13 pm ]
Irfanview is a good free app for resizing. One of many as stated. Even "Paint" works fine for resizing.
Author:  Duct Tape [ Fri Mar 08, 2024 8:22 am ]
Trying this again. Here is one of three rosettes after adding some purfling. My first attempts so still room for improvement but still happy with them. Thx for advice. Jon
Author:  Duct Tape [ Fri Mar 08, 2024 8:23 am ]
And another. Thx for resizer app tips!
Author:  bcombs510 [ Fri Mar 08, 2024 8:45 am ]
Nice save!
Author:  Ken Nagy [ Fri Mar 08, 2024 9:23 am ]
I have terrible eyes for detail. Even in these large photos, I don't see anything that could be improved. In real life, I probably wouldn't have seen what was bad in the first place! I can point out hawks, or herons, or deer driving down the road at 70mph though.
I do all my photos from my Mac. Sometimes I post from my Kindle, but I don't do photos from there. Sometimes some photos don't show up on it either. I don't know about the camera on my 10" Kindle. The one on my first one that couldn't even go on line was garbage, so I've never tried it.
I don't use my phone except for photos, and directions in the car! It's too small.
Author:  meddlingfool [ Fri Mar 08, 2024 9:41 am ]
Looks good!
Author:  J De Rocher [ Fri Mar 08, 2024 12:23 pm ]
Those look good for first rosettes. It looks like you've got the inlaying into the top part of it pretty well down. One thing that could use improvement for this style of rosette is to figure out a way to cut your tiles so that the radial edges are actually radial. Several of the spokes in each rosette don't line up with the center hole and it doesn't look like that was intentional.
