interface pads http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=56391 |
Author: | mikemcnerney [ Fri Feb 09, 2024 5:01 pm ] |
Post subject: | interface pads |
I'm ready to start sanding 3 instruments and have watched jeff jewitt use an orbital a 3 " I think, and I will be using a 5". He uses I think a .5" one on sides & back and nothing on the top. I already had the .5" but recently bought a .125 and a .375. Who uses them and which size where? |
Author: | bcombs510 [ Fri Feb 09, 2024 5:27 pm ] |
Post subject: | Re: interface pads |
I’m far from an expert so take this FWIW… I choose the interface pad based on the grit and what I’m trying to do. This is for polyester / polyurethane - I have zero experience with nitro. Initial leveling - 400 - hard block by hand or firm (sometimes called hard) interface pad for ROS. Finish sanding - 600 to 1500 - soft hand block (Kovax pink foam block or yellow Assilex block) or soft interface pad for ROS. The same for both 3” & 5” sanders. 2K & 3k - soft hand block (Kovax pink foam block or yellow Assilex block). No ROS Brad Sent from my iPhone using Tapatalk Pro |
Author: | bcombs510 [ Tue Feb 20, 2024 2:57 pm ] |
Is no-one else using interface pads? ![]() Sent from my iPhone using Tapatalk Pro |
