It is currently Sat Jul 19, 2025 9:02 am
 Post subject: Shop HEPA Air Filtration
PostPosted: Wed Feb 28, 2024 1:15 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
I was reading the thread on Whole Face Mask and Brad, @meddlingfool, @SteveSmith and others mentioned Honeywell air filtration.
Instead of hijacking the thread, I'm asking here.
Amazon has a Honeywell HPA3100 PowerPlus for Medium/Large Rooms (200 sq. ft.) that's in my budget. and a lot of other choices. What unit are you guys recommending/ using? I have a fairly small shop. Its "L" shaped and the ceiling mounted Jet filter is marginal. I've developed a mild sensitivity to breathing rosewood dust and have a pile of Zircote I'll be using soon :shock:
I've never used a HEPA air purifier.
Measure Twice,
Karl Borum
PostPosted: Wed Feb 28, 2024 1:55 pm
First name: Brad
Last Name: Combs
I bought this one - https://www.homedepot.com/p/Honeywell-P ... /312232605
It’s overkill but I like that I can go to the homer depot and get a filter whenever it’s needed.
Edit to add - I clean the pre-filter once a week and haven’t had to replace the hepa filters yet, I just got it last August.
These users thanked the author bcombs510 for the post: Kbore (Wed Feb 28, 2024 2:01 pm)
PostPosted: Wed Feb 28, 2024 2:17 pm
First name: Kent
Last Name: Fishburn
City: Woodstock
State: Illinois
If you have Commonwealth Edison for your electricity, you may be able to get a $50 rebate for buying an Energy Star appliance.
Kent
PostPosted: Wed Feb 28, 2024 2:36 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
What model is your ceiling Jet filter? The Jet AFS 1000 B I have on the ceiling is very effective with good aftermarket filters from Wynn Environmental. I have a Dylos particle detector so I was able to actually measure how effective it is at removing dust from the air. I posted a couple threads a while back (below) on how it performs. Since you already have a Jet unit on the ceiling, you may be able to get what you are looking for by just upgrading the filters in it. The Wynn internal filter is rated down to 0.5 microns. The Honeywell unit Brad linked to filters down to 0.3 microns so its filtration is slightly better.
https://luthiersforum.com/forum/viewtopic.php?f=10101&t=51479&p=677671&hilit=dylos#p677671
https://luthiersforum.com/forum/viewtopic.php?f=10101&t=51532&hilit=dylos
These users thanked the author J De Rocher for the post (total 2): Kbore (Wed Feb 28, 2024 5:22 pm) • bcombs510 (Wed Feb 28, 2024 3:08 pm)
PostPosted: Wed Feb 28, 2024 3:14 pm
Here’s mine, just a cheap little guy but helps a lot. In future I’ll be looking to employ bigger dust filters with the Wynn filters mentioned…Image
These users thanked the author meddlingfool for the post: Kbore (Wed Feb 28, 2024 5:22 pm)
PostPosted: Wed Feb 28, 2024 4:02 pm
Sorry I was misleading, I also have the Jet AFS 1000 on the ceiling but with the Wynn Environmental filters, which I think are HEPA filters? Anyway it works really well in my shop.
These users thanked the author SteveSmith for the post: Kbore (Wed Feb 28, 2024 5:22 pm)
PostPosted: Wed Feb 28, 2024 6:08 pm
I took the same steps as Jay with my Jet AFS1000 and got the Dylos meter. Very happy with the results. HEPA standard is a bit stiffer than what the Wynn filters provide, but not by much. My shop is 200 sq ft, so according to the Dylos, I achieve HEPA-like air quality in a few minutes.
Bill Pentz has a web site with a lot of good info on filtering and how to use the Dylos for fine particle detection.
http://billpentz.com/woodworking/cyclone/index.php
These users thanked the author Pat Foster for the post (total 3): Kbore (Wed Feb 28, 2024 6:41 pm) • J De Rocher (Wed Feb 28, 2024 6:37 pm) • bcombs510 (Wed Feb 28, 2024 6:16 pm)
PostPosted: Wed Feb 28, 2024 6:41 pm
First name: Karl
Last Name: Borum
Thank you for that excellent question. It's a stock JET outer filter for AF 1000B....
I went to the basement to get that information and as I climbed the ladder, it hit me (hard) that I had forgotten to ever check/ change that filter. It was very very dirty and waaaay over due to be changed. I actually had a new filter, stored on top of the unit, and its installed. I'm pretty disgusted at me self, I actually don't remember EVER replacing it. If I was my dad, I would deserve a good lecture...
It blows like a banshee now, thank you for asking about it :shock: And I should definitely have worn a dust mask.
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post: bcombs510 (Wed Feb 28, 2024 7:19 pm)
