Source for blades in LMI rosette cutter for drill press?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=56142
Author:  guitarjtb [ Sat Dec 23, 2023 11:50 pm ]
Post subject:  Source for blades in LMI rosette cutter for drill press?
I bought a used LMI rosette cutter for the drill press a while back. I need some replacement blades, but can no longer find them at LMI. Does anyone have a source for the blades.
Do you know if a blade is available to cut a .030" channel. The smallest blade I have cuts a 1/16" channel.
Author:  guitarjtb [ Tue Dec 26, 2023 9:02 am ]
Post subject:  Re: Source for blades in LMI rosette cutter for drill press?
Anyone?
Author:  Clay S. [ Tue Dec 26, 2023 10:50 am ]
I assume this is the tool you have: https://www.youtube.com/watch?v=3aGMy0nXp6U
For something as thin as .030" You might regrind something like an old pocket knife blade or even a Stanley knife blade. For thicker inserts you could buy a length of tool steel and regrind it to various widths.
Unless you are doing multiple rosettes to the same dimensions that tool looks like a PITA to set up and test (O'Brien seemed to indicate as much at the end of the video).
