Mixing Plastics http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=56002 |
Author: | TripodBob [ Mon Oct 23, 2023 9:43 am ] |
Post subject: | Mixing Plastics |
My previous guitars have all been done with ABS binding and pfurlings from LMI. Now with their limited stock I'm forced to mix ABS and PVC if I want to continue my usual design. Any thoughts on mixing ABS and PVC? |
Author: | RusRob [ Mon Oct 23, 2023 2:18 pm ] |
Post subject: | Re: Mixing Plastics |
I have never tried it and I would be hesitant to say it would work. I have done a number of binding using ABS but have not tried mixing them. I know from working on plumbing it is a no-go to glue ABS and PVC and under code you must have mechanical connection. The joint will fail. Maybe someone here has experience with mixing the two but I wouldn't think they will stick together. Otherwise you might go with ABS and that wood-like fiber stuff that is dyed Cheers, Bob |
Author: | Barry Daniels [ Mon Oct 23, 2023 4:08 pm ] |
If you use CA then it would probably work. Test on scrap. Also, abrading the surfaces of the plastic with sandpaper will always help with mechanical adhesion. |
Author: | Jim Watts [ Mon Oct 23, 2023 5:36 pm ] |
I’m guessing they would also age differently down the road, if that’s a concern, but don’t really know. |
