Serendipity
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=55537
Author:  Ken Nagy [ Tue Feb 21, 2023 6:02 pm ]
Post subject:  Serendipity
I cleaned up the Cello ribs today. The liners are glued in, but need to be tapered. I worked on getting the area of the bottom block where the original and replacement ribs joined together. I always think the join will be good, and it never is. I knew this one was going to be off, because when I was fitting it, it was too long. The plane when a little deep on the end, so I evened it out.
Yep, it has a mm gap. Way worse than normal. Usually you can just easily tell that it is there.
But the grain lines up like it was a one piece rib.I didn't even LOOK at the grain when I lined it up. Besides, it didn't have room to play around with the tapered ribs. So I cleaned out the glue from the gap, and glued in two, .5mm black purflings before lunch (dinner time) and I just went down, and planed and scrapped the extra mm or so off the black purfling. It looks great. It isn't the right way though, violin makers make perfect joins.
I never get them perfect. But the old masters didn't either.
They usually used on piece ribs on the upper and lower. No joins at all!
Author:  meddlingfool [ Tue Feb 21, 2023 7:10 pm ]
Post subject:  Re: Serendipity
Sometimes it works out like that!
