Jet 10-20 sander stripped height adjusting screw repair? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=55095 |
Author: | powdrell [ Tue Jun 21, 2022 7:06 pm ] |
Post subject: | Jet 10-20 sander stripped height adjusting screw repair? |
After 5 years of moderate use, the height adjusting screw finally gave out..... Looks like 8 hex screws to remove the shroud/housing to release the screw.....have the new part...supplier had minimal advise.... Just checking before I delve into it..... Inboard sandpaper clip is another....back-ordered for a while....been using medium viscosity CA with good results! Sometimes hi-tech isn't the best way...? Thanks in advance...... |
Author: | phavriluk [ Tue Jun 21, 2022 8:16 pm ] |
Post subject: | Re: Jet 10-20 sander stripped height adjusting screw repair? |
Any power tool maintenance shops available? These folks make their living keeping shop tools alive, and if they haven't seen that partricular problem, they've seen enough similar ones. |
Author: | powdrell [ Tue Jun 21, 2022 11:11 pm ] |
Done...gotta remove the drum....aprox. 16 hex screws and misc stuff.....give yourself 1 hr....need 3 sizes to remove hex screws....Not that complicated....just dont mix up threads, etc.... probably similar to replacing inboard clip....... |
Author: | RogerHaggstrom [ Wed Jun 22, 2022 12:58 am ] |
That happened to me too. The height adjusting screw is threaded in the soft aluminum cast, a terrible design. To fix it, the threaded hole must be drilled bigger and an insert in hard metal with threads matching the screw mounted. Not a problem if you have the tools and the right threaded insert. |
Author: | Marcus [ Wed Jun 22, 2022 11:06 am ] |
For me, it was the actual hole that stripped and couldn't grip the threaded bolt any longer. I used a thread repair kit and it worked fine for me. Dunno if that helps at all. https://www.amazon.com/gp/product/B0092QWZHY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 |
Author: | powdrell [ Wed Jun 22, 2022 5:06 pm ] |
Wow!!! Thanks guys! yep, it's the aluminum hole that is stripped!! Marcus THANK YOU for the referral on amazon for like $50. You guys are the best! |
Author: | mikeyb2 [ Thu Jun 23, 2022 4:02 am ] |
There is a guy from the UK who makes repair kits for these, because the manufactures parts are still not up to it apparently. His kits are sometimes available online. His name is Ken Timms and can be found and contacted through the UkuleleUnderground forum by the name "Timbuck". He also has Youtube videos showing how to use the kits, search for Ken Timms . |
Author: | Pat Foster [ Thu Jun 23, 2022 8:26 am ] |
Marcus wrote: For me, it was the actual hole that stripped and couldn't grip the threaded bolt any longer. I used a thread repair kit and it worked fine for me. Dunno if that helps at all. https://www.amazon.com/gp/product/B0092QWZHY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Marcus, Thanks for that info. Was it the 9/16-18 that comes up in your link? |
Author: | Marcus [ Thu Jun 23, 2022 10:37 am ] |
Pat Foster wrote: Marcus wrote: For me, it was the actual hole that stripped and couldn't grip the threaded bolt any longer. I used a thread repair kit and it worked fine for me. Dunno if that helps at all. https://www.amazon.com/gp/product/B0092QWZHY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Marcus, Thanks for that info. Was it the 9/16-18 that comes up in your link? Yessir, 9/16-18 |
