It is currently Sun Jul 20, 2025 10:52 pm
PostPosted: Sat May 01, 2021 3:35 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I marked the 4 transverse bars on the belly of the little Stauffer today. The plan doesn't call for a plate under the rosette, but I'm adding one. Just seems to be the best thing to do. It doesn't call for a bridge backer plate either, and I thought that would be a good idea as well.
Do the ball ends dig in without it?
Does it help the belly stay united with the bridge? I'd like that.
I have no diagonal braces. Would you make them wider, up/ down than the bridge? Longer?
Speaking of ball ends; the strings don't have them. Can you buy them, or drill holes in little hollow balls to make ball end strings? I'm sure that you could just tie big knots, but it seems that they would really dig in; one good knot at the end of a ball might look/work better.
Thanks, I have no idea.
Why be normal?
PostPosted: Sat May 01, 2021 4:03 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
How about beads from the craft store. Run the string thru and tie a knot.
PostPosted: Sat May 01, 2021 9:32 pm
Hard maple makes a good bridge plate, and this does help to strengthen the bridge area a lot. Use snug fitting bridge pins; I like the unslotted ones.
PostPosted: Sun May 02, 2021 9:27 am
First name: Ken
Last Name: Nagy
City: Goodrich
Nice suggestion Carl. Thanks.
The bridge will be maple, and the backer plate. The bridge is on the smaller size, though it does have the remnants of a mustache. It is very thin. The saddle itself is only about 10mm or less above the top. The area where the pins go is about half of that, I think. Maybe more like a strong, flexible bridge? The backer and bridge making the whole thing more like 3 ply plywood? Strong, but not so unidirectional?
Why be normal?
Users browsing this forum: TimAllen and 21 guests
