It is currently Sat Jul 19, 2025 5:23 pm
PostPosted: Sun Mar 28, 2021 3:56 pm
Bought a set that seemed a bit thin at 3.2 and after jointing and leveling with P100 grit on the 10-20 was at 2.5-2.65 mm.
Target thickness was 2.4-2.5 mm.
Rather than risk the drum sander, I got out a Veritas scraper plane to try for the thickness I wanted, and I like the results.
First time I've used it in anger (although I did practice sharpening and setting it up, taking some shavings on rosewood previously)
I think this tool will be seeing more use from now on.
These users thanked the author Colin North for the post (total 2): Durero (Mon Mar 29, 2021 1:42 pm) • bcombs510 (Sun Mar 28, 2021 5:02 pm)
PostPosted: Sun Mar 28, 2021 5:34 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I use scrapers and planes all the time, so I'm not surprised it worked. I don't have a scraper plane though.
That stock is very cool! What is it?
Why be normal?
PostPosted: Sun Mar 28, 2021 5:49 pm
Black Limba
PostPosted: Sun Mar 28, 2021 6:05 pm
I also use scrapers and planes a lot, probably have 6/7 scrapers including the "ultimate" SM.
A scraper plane definitely has a learning curve, both to set up and to use, but can give 55-60 mm wide very thin (sub-thou) shavings on a level board.
PostPosted: Mon Mar 29, 2021 10:56 am
I have the same plane. A bit of a learning curve but works great.
PostPosted: Mon Mar 29, 2021 7:55 pm
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
I like my LV as well. Have 3 scrapers for it, the one that came with it, an extra thick one, and a KUNZ replacement scraper blade. I/ve found different setiing angles work better with some woods than others. The blades have differing angles as well 90 45 an 35 .
PostPosted: Tue Mar 30, 2021 5:22 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
A lot of woodworkers prefer the Stanley 80 and clones. Easy to set up, easy to use, results just as good, and cheaper to boot.
Ed M
PostPosted: Tue Mar 30, 2021 5:54 am
Ed M
Yes, I can buy a decent clone for less than $35 new, but I like the longer sole of the plane for thicknessing.
Got it with a low-ball bid, second hand, virtually unused, on the bay.
PostPosted: Tue Mar 30, 2021 8:32 am
So do you sharpen a scraper like you would normally for hand scraping the same way for that plane? I could see that being very useful as scraping gets tiring on the hands.
PostPosted: Tue Mar 30, 2021 8:40 am
I use a Stanley#80 cabinet scraper, but also have this Sargent #42 veneer scraper (similar to a Stanley #12), which is kind of in between a cabinet scraper and a scraper plane - it has a longer sole than most cabinet scrapers, and you can adjust the angle of the blade to suit the wood. I sometimes use the blade as a hand scraper so now I'll have to go track it down. [headinwall] laughing6-hehe
You can make your own scraper plane if so inclined:
https://www.youtube.com/watch?v=wfZzd3xi8l8
PostPosted: Tue Mar 30, 2021 9:15 am
Last Name: Minch
City: Chestertown
Clay
Really like his video on making the plane body. Surprising amount of bounce in his heavy bench when he cuts the mortice.
The 80 must be a little understood tool as I have owned a couple and seen a dozen others new in the box. This fellow does just what the original Stanley instructions say to do when sharpening the blade.
Ed M
PostPosted: Tue Mar 30, 2021 11:40 am
Veritas instructions are - Bevel/sharpen at 45 degrees to 6000 grit, turn a burr in a couple of steps with the final one at 15 degrees.
PostPosted: Wed Mar 31, 2021 10:40 am
Ruby50 wrote:
Clay
Ed M
Hi Ed,
I re-viewed the video and it looked like he was working over his vise when chiseling through the plane body which may account for some of the "bounce". I guess that saves marring the bench but seems a little hard on the vise, but maybe not.
He has a number of videos on plane making, so I will start a thread linking some.
Edit: After watching another video, you are right , Ed, his bench does move a lot!
