Pinless acoustic bass bridge replacement http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=53985 |
Author: | nathanpeirson [ Sun Feb 28, 2021 3:11 pm ] |
Post subject: | Pinless acoustic bass bridge replacement |
Hi folks, I have a Fender acoustic bass with a pinless bridge. When I got it the bridge was cracked down where the ball end lives. I assume the prior owner was putting strings with larger ball ends and cracked the bridge. My question is, can I replace that bridge with a traditional pin style bridge? I assume I would have to add a bridge plate, but I wonder if there are any other considerations I should be aware of? As always, thank you for your responses. |
Author: | Barry Daniels [ Sun Feb 28, 2021 7:39 pm ] |
Post subject: | Re: Pinless acoustic bass bridge replacement |
If you want to go that route, I think the main concern would be maintaining the structural integrity of the braced top. So make sure that none of the new bridge pin holes intersect a top brace. And you are correct that a bridge plate will be necessary. I like to use hard maple but rosewood is acceptable too. |
Author: | phavriluk [ Sun Feb 28, 2021 8:50 pm ] |
I suggest OP put an inspection mirror in the soundhole and see if there's already a bridge plate present. I think they're used to stiffen the bridge/top/bridgeplate lamination and only incidentally used to retain string ball ends. |
Author: | CarlD [ Sun Feb 28, 2021 11:11 pm ] |
Nathan, I've built two ABGs, one with with a pinless bridge that had a substantial bridge plate per the Mark Stanley plans. The other that still needs finishing will have a Martin pinned bridge ( I got a Martin 2nd fretboard/neck and bridge somewhere). Both have Maple bridge plates. I think it's most important to have the wings of the bridge over the x-braces. |
