StewMac buffing wheels...is centre plate removable? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=53874 |
Author: | charlton [ Tue Jan 19, 2021 12:04 pm ] |
Post subject: | StewMac buffing wheels...is centre plate removable? |
I have an arbor that is 1-1/4" and the StewMac buffing wheels have a 1" centre plate. I emailed them to find out if the centre plate is removable so that I could potentially replace them with a centre plate that has a 1-1/4" bore but I was told that they are not removable. Can anyone with StewMac wheels confirm this? If they are removable, my plan is to get some 5" centre plates. I'm in Canada and have a difficult time sourcing airway buffs. I've also considered just getting the canton flannel buffs from Caswell but it seems like the general consensus is to go for both canton and domet buffs. Thanks, Charlton |
Author: | bcombs510 [ Tue Jan 19, 2021 12:23 pm ] |
Post subject: | Re: StewMac buffing wheels...is centre plate removable? |
I would say they aren’t “intended” for removing them. Here is a pic that might help. Anything is removable if you’re motivated, but the material might not make it out the other side. ![]() ![]() Hope that helps. Brad Sent from my iPhone using Tapatalk Pro |
Author: | bluescreek [ Tue Jan 19, 2021 12:36 pm ] |
NO! go to creswell plating or Grizzly a shim is easy to manufacture |
Author: | charlton [ Tue Jan 19, 2021 12:40 pm ] |
Hi Brad, Thanks for the photos. I believe that is the design of all centre plates. Is the centre plate like that on both sides? Normally they are just put in on one side (crimped in place but sometimes welded in place). ![]() As an example, here is someone who pops it out with a whack (not suggesting you try this, of course). ![]() https://youtu.be/DjUesIAhEAc?t=136 Maybe this whole endeavour is more hassle than it's worth. ![]() |
Author: | charlton [ Tue Jan 19, 2021 12:43 pm ] |
bluescreek wrote: NO! go to creswell plating or Grizzly a shim is easy to manufacture Shipping from Grizzly to Canada is pretty much a non-starter these days. Caswell plating has buffs but the only one they provide with a 1-1/4" bore is the canton flannel. It's not an airway buff (not *really* sure if that makes a difference in the grand scheme of things). |
Author: | bcombs510 [ Tue Jan 19, 2021 1:26 pm ] |
charlton wrote: Thanks for the photos. I believe that is the design of all centre plates. Is the centre plate like that on both sides? Normally they are just put in on one side (crimped in place but sometimes welded in place). No problem, I’ll take your word for it they are all alike. I’m just a user. [FACE WITH TEARS OF JOY] Here is the other side: ![]() Brad Sent from my iPhone using Tapatalk Pro |
Author: | charlton [ Tue Jan 19, 2021 1:37 pm ] |
Thanks again, Brad. It does look like it's just a single plate with tabs bent over on both sides. Doesn't look like it would be difficult to just bend the tabs to remove it if I decide to go this route. Much appreciated! Charlton |
