What is this fastener called? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=53814 |
Author: | bcombs510 [ Thu Dec 31, 2020 10:44 am ] |
Post subject: | What is this fastener called? |
Good morning. I've spent too long this morning trying to think of what this type of connector is called. I'm memorizing the McMaster Carr catalog but not getting closer to what I need. ![]() Attachment: SM.jpg It holds the foot of the bridge clamp caul in place but also lets it spin freely so that the foot stays in place while the bolt is turning. I started with swivel bolt, but that's not it! Brad |
Author: | Michaeldc [ Thu Dec 31, 2020 11:37 am ] |
Post subject: | Re: What is this fastener called? |
Press insert? https://www.mcmaster.com/press-inserts |
Author: | Ken Lewis [ Thu Dec 31, 2020 12:17 pm ] |
Those are probably purpose made. You could make something like this work, I bet. https://www.mcmaster.com/miniature-thru ... -bearings/ |
Author: | SteveG [ Thu Dec 31, 2020 1:01 pm ] |
Like the pad on a C clamp ? Maybe - a swivel pad known as toggle and swivel-foot pad. https://www.mcmaster.com/swivel-pads/sw ... d-studs-6/ https://www.mcmaster.com/swivel-pads/ Cheers |
Author: | ballbanjos [ Thu Dec 31, 2020 1:25 pm ] |
Try swivel foot bolt. https://www.mcmaster.com/swivel-feet Whoops--sorry for double posting this! I'm too slow... Dave |
Author: | bluescreek [ Fri Jan 01, 2021 10:08 am ] |
toggle pad |
Author: | bcombs510 [ Sat Jan 02, 2021 10:28 am ] |
Thanks, all! This was helpful and I’m on the right path now. Sent from my iPhone using Tapatalk Pro |
Author: | Bryan Bear [ Sat Jan 02, 2021 11:56 am ] |
Too bad I didn’t see this earlier. I just made a set of these cauls and couldn’t figure out a way to have movable feet that o liked. I ended up just taping the threads in a mild steel bar and I laying that into the bottom of my caul. I then added a sacrificial price of thin hardwood that is only screwed in the center to get pressure on the wings. I always make a clamping pad from thermoplastic to match the top is the bridge so I could get away with the bottom of my caul being flat. ![]() ![]() Sent from my iPhone using Tapatalk |
